Pics & Review of My Bilstein PSS10 Lowered Red Turbo
#797
@cannga Do you know if the stock height can be maintained with the Bilstein PSS10 ?
"FYI and one more important piece of info: For the Turbo, Bilstein's official recommendation is that ride heights be reduced 10mm-30 mm in the front, and 5mm-25mm in the rear. That is, they actually recommend that you do not use stock ride height, and that at least you should try to lower 5mm."
https://www.6speedonline.com/forums/...ml#post2758673
#798
Hi & thanks for the nice comment. Tom is alive and doing very well, busier than ever. His cell is # 310-733-7324, you could call or text him. He's an incredibly experienced and knowledgeable Porsche tech and has done all the important suspension work in my car; I do recommend him very highly. As a bonus his rate has always been very reasonable; no bs extra charge.
Lucent is also a GIAC dealer I believe, so if you are interested in an ECU mode, ask him about it. The advantage of being in LA is that you might be able to convince GIAC to do a custom tune for you, instead of just the generic one. This means they'll bring your car to GIAC shop and tune it on the dyno; IMHO a huge advantage over the generic tune and we are lucky to have it because GIAC is local.
Good luck and have fun. The Bilstein Damptronic will absolutely TRANSFORM your car.
