Sponsored by: Bears Transport
Official response from GIAC to comments in locked thread 136635...
Old 07-21-2008, 11:32 AM
Josh/AWE's Avatar
Originally Posted by imcarnuts
Does Champion do something to tweak theirs or does GIAC make a special flash for champion?
Duffy,
No to both of those questions.
For the stock turbos, all G.I.A.C. flashes are the same.
  #92
Old 07-21-2008, 12:08 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Originally Posted by noah677
I don't agree as long as the vendor uses common sense With common sense being used, the vendor probably has a lot of good info to share
you do not have to be a moderator to give good info.
  #93
Old 07-22-2008, 12:01 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I don't think it can be over emphasized that getting a bad CEL is not a bad thing. It is a good thing! The ECU is telling you somthing is wrong with your system so that you can fix it before a catastrophic failure occurs! All the complaints about the software causing CEL's is about the same as complaining that the oil pressure gauge reads zero. The warnings are there to protect the car, not to irritate the driver.
I chose GIAC specifically because the self-diagnostics are not tampered with. I don't want the acceptable tolerance ranges increased just to compensate for suboptimal tuning or components. It's like wanting to grow up in a super lax household vs a strict household. The strict household is supposed to keep you out of more trouble. I would be suspicious if a flash suddenly eliminated all the CEL's that my car was getting - as if you simply unplugged or deprogrammed the CEL lightbulb.
  #94
Old 07-22-2008, 12:55 PM
TT Surgeon's Avatar
Hey guys, any truth to the rumor that if you bump up the rev limiter with a flash, every time you go above 6750 it will record as a type 2?
  #95
Old 07-22-2008, 01:04 PM
bbywu's Avatar
Yes, an overrev is recoreded not only in the ECU but in the other systems as well...and the 997's ECU not only recorders type 1 and 2, but now break up the data based on RPM range.
The 6 ranges are
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 3: 7700-7900 RPM
Range 4: 7900-8400 RPM
Range 5: 8400-9500 RPM
Range 6: 9500-11000 RPM
  #96
Old 07-22-2008, 01:13 PM
eclou's Avatar
Yes it records it but I think those ranges are too high i.e. range 1 starts much lower on a 997tt
  #97
Old 07-22-2008, 01:17 PM
TT Surgeon's Avatar
So, is it better to keep your rev limiter set at 6750 when you flash, as I know the tendency is to bump it up a couple of hundred rpm.
Prolly a mute point, once you flash .
  #98
Old 07-22-2008, 01:41 PM
bbywu's Avatar
This is where I got my info...could be for the 997 non turbos...
Old 07-24-2008, 01:41 AM
SamboTT@ByDesign's Avatar
You can choose either to raise the limiter or leave it stock with GIAC. The extra RPM is only for certain applications anyway. (1/4 mile runs with no need for 5th gear, in road racing you can rev-out a gear before a turn so there is no need for an up/down shift) It usually does not make the car any faster. May aswell keep your piece of mind.
NIKAS
08-20-2019 07:53 PM
manfred@loma_wheels
09-02-2015 11:22 AM
Quick Reply: Official response from GIAC to comments in locked thread 136635...
