Save $$$$ on HRE Cause we are BUYING Your Stockers!!!
We are still running this promotion for HRE Wheels. I have a couple new sets instock. If you missed out on the HRE open house, check it out in the 997Turbo forum. Here are some pics -
All of the monoblocks way about 20lbs on the front and 23lbs on the rear in 19". If you want a really lightweight wheel, then you need to go with the C series. They hone out the back of the spokes to reduce material. They ensure strength is still there. When the wheel is assembled with the outer hoops, titanium hardware is used. The center weigh an amazing 7lbs each!!!
For your inquire on trade in value, please follow the instructions above and we can quote you no problem.
In the spirit of accuracy, I suggest you get your scale fixed.
Hey thanks for that pleasent post I did say about because who says my scale is accurate. I was off 1.5lbs in the front and 2lbs in the rear compared to your info. I will make sure Marc from HRE chimes in with the appropriate info. Thanks again!
WheelB
01-06-2018 12:08 PM
L.A.P.
10-26-2015 12:49 PM
ModBargains
08-20-2015 01:28 PM
