Sponsored by: Bears Transport
Tire Pressure 997TT
Old 07-31-2008, 10:25 AM
cannga's Avatar
Porsche's recommendation is 33 Fr, 39 Rear for "partial load." If you have rear warning at 39, then most likely your car was set to "full load" (driver, passenger, luggage). This setting could be changed by using the steering column stalk, go to "TPA," the rest is self explanatory.
Before installing Bilstein PSS10 coilover, my tires were set at 34-35 front, 40-41 rear. The stock car's suspension was so soft that I had to compensate by over-filling the tires.
After installing the Bilstein PSS10, I am now back 33 front, 39 rear. Hope this helps.
Originally Posted by ERSKATEDOC
When I got my 08 997TT, I had my detail guy remove all the decals from the door jams.
Unfortunately, one was the tire pressure sticker.
I got a low pressure warning (39 PSI) for the rear left.
What pressure should I have in the front and back tires. They are pirelli P zeros (Factory tires).
All the tire says on the sidewall is Max PSI 50.
Old 07-31-2008, 10:48 AM
Texas911's Avatar
Texas911 is infamous around these parts
I run 33-39, 44 in the rears is too hard for street use.
Old 07-31-2008, 09:35 PM
TT Surgeon's Avatar
40 all around on the street. Track 32fr/36r HOT.
Yes, don't forget to set it at partial load, I did the same thing!
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
The Oss
08-24-2015 08:19 PM
Quick Reply: Tire Pressure 997TT
