Tire Pressure 997TT
Old 07-29-2008 | 09:54 PM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
Tire Pressure 997TT
When I got my 08 997TT, I had my detail guy remove all the decals from the door jams.
Unfortunately, one was the tire pressure sticker.
I got a low pressure warning (39 PSI) for the rear left.
What pressure should I have in the front and back tires. They are pirelli P zeros (Factory tires).
All the tire says on the sidewall is Max PSI 50.
Old 07-29-2008 | 10:11 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I run 43 rears and 38 fronts.
Old 07-29-2008 | 10:12 PM
GEE-BEE's Avatar
GEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of light
Wink Psi
37 front , 44 Rear
Get a nitogen tank and regulator and hose on ebay is a option....
I paid :
75.00 for the N2 Tank 60 Cubic ft (New )
60.00 for the Nitrogen Reg 0 / 200 Psi( New )
5.00 for the coil Hose
12.50 for the filler with built in pressure gauge
15.00 at the local air supply hose for a nitrogen 65cubit ft tank / 1500 PSI
I rarely put nitrogen in the tires now, better for the tires since it's a dry fill, and pressure maintains what you put in since it doesnt expand with heat
Or you just go down to Big O tires and have them switch the air for N2 for you for 24.95 and get free Re-fills
Gee-Bee
Old 07-29-2008 | 10:15 PM
turbojohn54's Avatar
turbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud of
Just got my TT coupe last week. It also came with Pirelli P Zeros. My door jamb sticker says cold inflation pressure is 37 psi-front, 44 psi-rear for fully loaded vehicle.
Owners Manual says 33-front/39-rear for partially loaded vehicle (up to 2 persons without luggage).
Old 07-29-2008 | 10:35 PM
TXTurbo's Avatar
TXTurbo is just really niceTXTurbo is just really niceTXTurbo is just really niceTXTurbo is just really nice
If you have aftermarket 20's what do you set the tire pressure to?
Old 07-29-2008 | 10:51 PM
yrralis1's Avatar
37/44 for me but with one caveat .
On my last car (a 997S ) the door jam number was different than the manual .
I adhere to the manual .
Old 07-29-2008 | 10:54 PM
Barrister's Avatar
Barrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to behold
Good advice.
Old 07-30-2008 | 12:28 AM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
I have Bridgestones and like (cold) 33 front 37 rear.
Old 07-30-2008 | 06:49 AM
Serpentene's Avatar
Serpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant future
Michelin Pilot Sport on mine. 37/44
Old 07-30-2008 | 06:54 AM
brownan's Avatar
brownan is a jewel in the roughbrownan is a jewel in the roughbrownan is a jewel in the rough
38/44 hot
- note that you can adjust whether you are running partial or full load via the lower left column stalk (the one for the menus below the tach). If it is set of full load you may want to switch it to partial load unless the car is full of people and stuff.
Old 07-30-2008 | 08:21 AM
meaker's Avatar
meaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to behold
I'm running 34/40 cold...
Old 07-30-2008 | 10:58 AM
BRN 997 TT's Avatar
BRN 997 TT is infamous around these parts
I have the same problem, I just need 0.3, so refilled it, anyhow now I'm having difficulties reseting it somehow.
Old 07-30-2008 | 12:08 PM
RTEAMSTRADALE's Avatar
RTEAMSTRADALE has a spectacular aura aboutRTEAMSTRADALE has a spectacular aura aboutRTEAMSTRADALE has a spectacular aura about
Check the manual there are different pressures for different loads (people + luggage). PS2's - Have run mostly 33/39 cold = One person no luggage. Now running 36/42 cold.
Old 07-30-2008 | 12:09 PM
Make sure you drive for a while in order for them to reset. Could take 10-20 miles or so, sometimes less.
Old 07-30-2008 | 02:30 PM
colesporsche's Avatar
colesporsche is infamous around these parts
Is this the same as a 996tt? Or is the tire pressure different for those?
Quick Reply: Tire Pressure 997TT
