white residue on exhaust - throwing CEL error ?
#31
I have FS, no issues so far, they use the HJS cats.
I'd call whoever you bought the system from and see what they can do.
c
#32
Okay. Just had the dealer check my car. These are the error codes:
2099 and 2097 - something to do with o2 sensors detecting a rich mixture - one is for bank1 and the other is for bank2.
So - because my car is not having bad gas mileage, no unpleasent odor or loss of power - they are of the belief that I am lucky and all seems fine (but of course they didnt take things apart just yet).
They simply reset the hard codes displayed and I have now driven 100 miles or so since then and no CEL.
What is wierd about all of this - is that I put the leaded fuel in (mixed with unleaded about 2 leaded to 1 unleaded ratio) and nothing happened. It was only about 2 tanks later on normal gas that these codes came up.
I have a horrible feeling I will get the CEL again. But not sure. If I do, the first thing they are going to do is replace the o2 sensors and see if that fixes it. If not, then it is a new exhaust.
I will report back when I am up to about 500 or so miles. But thanks again for all your input - my fingers are constantly crossed now :-)
#34
they could tell immediately (my exhausts looks as though they have run hot at some point). I just didnt admit or deny it. I know them pretty well prior to buying cars there. they may give me a break if things take a bad turn - at least I am hoping. I have bought 3 cars recently from that dealership.
#36
#37
If you were at the dealer recently that could explain it, there is a TSB out there to reflash some 07 and 08 TT cars due to idling problems. I was there Monday, they wanted to do mine, but I told them not to bother it's fine. If they reflashed your ECU they may have done so to the new 08 specs, which tend to be a little more sensitive to the cats. A guy on RL had the same issue.
c
c
#38
#39
what was/is causing yours ?. cat failure? or sensor failure ? - what caused this ? a modded exhaust ?. it wasnt clear on your post - at least to me.
#41
That's not the code for a bad cat, I'll look up the correct one. That might just be a sensor. I bet they reset your ECU, only takes a second once they plug into the OBDII port.
#45
500 miles and blasted it too for the last 100 with some spirited drives and a PCA event. fingers definitely still crossed. no CEL.
