sports cams in 997 TT....
in any case i think you should ask you tuner who will be doing the installation. different cams are recommended depending on the overall combination and results you are loking to achieve. i would not start playing with cams unless you have a specific goal in mind.
997 tt stock cams are not so bad so there is no much space for improvement or you want to
At first we should find the source for the sport cams......
Hi karol..this is nice power...is that power in DIN?....in what boost you have this power?with stock internal?
Is the drop off at 6600RPM typical for an engine dyno?
Is this a factory engine? Or does it have stronger Rods, Pistons?
