Clutch Pedal Engages ... where???
When I first got the car I thought that it activated too high also compared to my E46 M3, but you get used to it fairly quickly.
It's actually pretty good in stop/go traffic on the street but its awkward to launch the car. I dont really launch it ever so that doesn't bother me.
I've only tried "launch" about 4 times. I don't like it. Seems like it's going to break something. It's certainly faster than I can do on my own, but it just doesn't 'feel right'.
I also attribute that to the long throw of the clutch pedal and the 'time' used with pedal travel.
I'll probably change out the pedal system as Sharky suggested once it's out of warranty.
Thanks all..
Thanks all..
Once again, glad to know I am not alone here. I've only had 2 days of drive time and I am desperately trying to get used to the clutch engaging high. May be it's just me but it's been challenging trying to do smooth shift between 1st and 2nd. Please let me know if anyone has any advice... may be I need a driving lesson.
Then I opted for the Gt2 conversion and by far it was the way to go. It removed the power assist which makes the clutch quite hard to press but I can nail the engagement point spot on and it is strong enough to hold the Hp upgrade. It was not a simple job . In fact on the 996tt I heard it takes less time (6 hrs rather than 10) . Once completed I love my clutch setup.
Not weird at all. I did the same thing! Think it's because the pedal is easier to modulate with the muscles controlling the ankle rather than the less precise (but stronger) quad/hamstrings. Problem with this position though is if you're frequently changing gears, your leg will likely fatigue faster.
The GT2/slave removal mod only helps in terms of feel of engagement, especially for those with upgraded clutch/flywheel combinations that feel like on off switches. It does not change the engagement point.
You can change the clutch engagement point by changing the length of the slave rod.
jaehoppa
10-22-2015 09:17 PM
