Clutch Pedal Engages ... where???
I'm not happy where my clutch engages in the range of pedal travel. It seems to engage at the top end of the range of travel. To be precise, if the pedal is depressed all the way to the floor, that would be '1', and if released all the way, it would be a '10'.
My pedal engages/disengages between '6.5' and '9' ... and for me this is just too high. The dealer service tech (mediocre staff at best) said that's the factory placement and I should leave it there. (Can't believe that).
Well ... where is your engage/disengage range? And have you adjusted it closer to the floor?
Thanks.
Thanks.
Thanks.
Thanks.
Totally agree!
that's normal on the 996 and 997TT's and part and parcel of the hydraulic assist. I don't like it either and much prefer the "feel" of a GT3/GT2. The TT's set up is doing the work for you and you don't feel it engage and it feels more like a switch;( There are a bunch of different conversions out there that remove the system. Try a GT2/GT3 clutch pedal and see how you like that and the engagement first though.
Sharky -question --does the Gt2 pedal have launch control ?
Saintly --I really don't like the clutch . Never did . In fact compared to my 997S (previous two cars) the power assist really has been a disappointment. When I upgraded to a stage three clutch I now have a more more aggressive clutch but still have the awful Porsche factory hydraulic assist feature . I am considering other options but I am concerned about a hard to press non assist clutch in traffic--so I have just adapted . Plus with 700 Hp my choices are probably going be more limited than yours.
yrralis, the GT2 has a separate launch control system that the 997TT doesn't have. It's not a feature of the clutch.
SHARKY seems to have an answer. Hate to push you for details, but is this just a 'pedal swap' or is it more technical than that?
Is there's an adjustment without changing out the pedal and armature?
Thanks.
Thanks.
http://www.sharkwerks.com/products.php?pid=162
We do them a lot on the 996TT's with big power kits or once the slave cylinder's being to fail....
I just don't want to mod the sled in a way that'll blow the warranty. Seems Porsche is getting stricter and tighter with mod's that will void warranties, and I'm certain this will be one of them. I may change out, modify the armature of the pedal. Even if I get an inch or two it'll help a lot.
I need to know why they allowed all that useless play at the end of the throw - is it part of the launch-control process?
Thanks for indulging my knowledge/understanding quest.
I know that REALLY means they're watching me closer than normal.
Funny thing about the clutch business. I'm teaching my son to drive a stick (the turbo is the only manual we have) and he complains about the lack of feel where the clutch engages. I'm used to it now but it bothered me at first, coming from a 930. I reassured him that I stalled the car plenty of times too, until I got the hang of it.
I know people complain that its soft, but I don't mind. Personally, I wouldn't change the whole setup just for that. I will be getting a 6GT3 for track duty, so I will be curious to compare the two.
