Keithta 997TT New Record 60-130 & Drag Strip 1/4 Mile Run
Keith
To answer your question, my car did these runs including the 1/4 mile pass with the full body kit and stock 19" wheels and tires. Car is also full weight and running AWD.
My avatar photo shows my car with the 20" HREs I drive around with daily. I usually shave 1-1.5 tenths off my 60-130 times when I pull off my 20s and run with the 19s. With that said, my car should pull a 5.5/5.6 with the 20s.
Keith
Keith, great trap and 60/130!! Hows the car the car holding up at those power levels, particularly the stock engine? Is that kit topping out the 3071s or is Todd tuning it based on the threshold of the engine? And lastly, were your runs on 19s/20s?
Again, awesome job!!
The car internals havent missed a beat thus far. Todd tuned this setup with the stock motor in mind. I havent reached the threshold power output of the 3071s yet as I havent tried turning up the boost high enough - but Im sure Im close. My guess is that turbos will be maxed out at around 1.5-1.6 bar. But I believe Id run out of fuel before reaching those boost levels since Im running the stock injectors and factory fuel system.
I have done passes before with the 20s. All my runs in this post were done using the stock 19s and tires (60-130s and 1/4 mile runs).
Thanks.
Nevertheless, I may want to stay with AWD since it keeps the car well planted and is safer when I want to drive more aggressiveley.
Also, I have heard that the 997TT's AWD system is a bit more sophisticated than that of the 996TT. I was told, when traction is not an issue, it loses less power than the 996TT under acceleration due to the way it shifts more power to the rear wheels.
Dont quote me on this as I have not researched this area much. This is just what I have "heard" along the way.
Anyone know anything on this subject??
Keith
My car left Protomotive running a 6.31 at 701 awhp at 1.25 bar. During this run we didnt know that there were some boost leak issues linked to some heavily crimped boost lines. We were also running the stock air filter and air box.
As time went on, my problems worsened - melted boost hoses/holes in lines etc. I would guess that my car was pulling a 6.6 on the video you referenced above then and grew even worse around the time I raced Chris Greens car (maybe a 6.8 at that time). Shortly after that race between Chris and I (1 week later) my car hit rock bottom on the performance side. The car would barely get out of its own way. Once we fixed the boost related issues, improved the intake design, the diverter valve configuration, bumped up the boost to 1.4 bar, the car dropped into the 5s.
04-28-2022 12:38 AM
Lowtush
01-25-2022 10:48 AM
turbotuner20v
09-11-2015 12:02 PM
