Click Sound from Clutch Pedal ??
I noticed awhile back a clicking sound generated from when I let off the clutch pedal, usually in the last 50% where the point of engagement is. Aside from the noise, what was even more noticeable was the slight pop I felt on the ball of my foot from the clutch pedal.
Long story short, I took it into the dealership 6 months ago and they identified it comming from the clutch assembly, but visually did not see any damage. They ultimately decided to replace the pressure plate and the throw out bearing which in the end solved the problem.
Just yesterday the noise and pop came back again This time, however, it does not does not pop or make the audible sound all the time. Just more so when I shift from 3rd to 4th and when I am letting of the clutch fast.
Has anyone experienced this issue with their car? I am going to bring it in again next week. Is this normal? I tend to be overly paranoid as well! Aside from that the car drives perfect.
I have a slight click at 75% depressed position...but it is so subtle that you don't notice if it the engine or stereo is on...and the sound comes from within the cabin...not under the car.
I noticed it on day one...2 years later, no problems.
mine will pop on occasion, sounds like plastic popping from the clutch pedal. Im quite **** about noises but this one is not bothering me so much...I think its just the plastic parts making a bit of noise, nothing serious.
Clutch grabs fine, is relatively consistent in engagement etc.
It is normal from what I was told. It is the hydraulic assist when it is engaging/disengaging. I brought it to their attention early on and that is what I was told. They could be wrong. It hasn't caused any problems for me.
They replaced my pressure plate at another dealership about 6 months ago and it resolved the problem, but the noise just started up again last week. Do you know why this might have just solved the problem temporarily?
Thanks!
I am having a similar problem and have taken it to the dealer 3x now. They told me they took it apart and lubed the hell out of it. Still have the problem and its pissing me off. Anyone have a fix???
The clutch is not going to be silent, in reference to the actual pedal and assembly. Now if you feeling a popping well that sounds like a dealer visit, but noise is going to occur.
I had the brake pedal make a clicking noise, ended up it required some lubricant now all is good.
10-06-2015 03:43 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
