Brake and Differential noises
So I put about 1600 miles on my '08 Turbo so far, and besides from the clicking noise from the passenger seat I've also noticed some other noises.
First the brakes, they squeak slightly when I'm coming to a stop slowly, usually it happens the last few feet right before I come to a complete stop. Or if the car is rolling backwards slowly with me covering the brakes. I had Brembos before and they squeaked so I'm guessing this might be normal for performance brakes?
Second the differential noise. This usually happen when the temperature drops to under 40F and the car is cold or has been parked for a while. If I have the steering wheel in full lock or close to it and when the car starts moving I hear some kind of popping noise from the front of the car and I can feel the car pop/skip. It almost feel like the center diff. binding when it's cold on my old STi. But once the car has been running for a while and is warm, it doesn't do it anymore. Is this normal for the AWD system on the TT or should I get it checked out?
TIA!
TIA!
So nobody else has the noise from the diff/wheel?
It only does it when it's cold, and the car is moving slowly with the steering in full lock. Feels like the wheels are skipping.
I replaced the tires to snows for the winter and the noise is gone.
Im guessing its cause the summer/performance/cup tires have no grip at that temp and so the AWD system gets confused when they skip. Nothing I think you can do except wait for it to warm up or swap out the tires.
I had the same exact thing and at first I thought it was my suspension, but then I realized that it was actually because like you described low temperatures around 40F or lower and I still had my michelin pilot sport cups on and those things are hard as rocks at that temp and in the morning.
the reds squeal, at least after a few days from cleaning when the dust builds up. Ive found after a wash they dont for a few days then they do so at slower speeds when coming to a light stop...its normal.
Noises
TIA!
TIA!
TIA!
TIA!
The brake squeal appears to be an inherant issue for 997tt's . Dont ask me why but my 997S never did it .
My 997tt does exactly as you say (when coming to a standstill) a squeal from time to time on the LHR rear . Porsche replaced my rear pads just last friday. So far the squeal still comes intermitently but not as loud as it was before so maybe when these new pads bed in a bit more it may go away once and for all (hopefully). They also did a deglase on the discs. I notice the squeal manifests when the ambient temp goes over 27 Cels whereas below that they never squeal .
Its 40 deg C here in Sydney today so my guess is they will play up on they way home....shortly.
Secondly your popping binding noise in the front end is just the tires (PS2) nothing more. My previous C2S did the same thing as well every morning. My 997tt does it every single morning after the car has been standing overnight and moresoif ive been a way for a week. My garage has a billiard table finish concrete floor so it makes the noise really obvious. I put it down to the super low profile tires getting a flat spot from standing on the one spot too long. Once you get going tho the tire corrects itself. back to nice and round . For eg if you are turning right out of your parking space it will make the noise on the left front wheel and..so on. correct?
