New 997 turbo...doesn't feel as fast as my m6 part2
This is follow up to a thread I post yesterday. I cannot post on that thread because it says my account is not activated. I decided to re-post this because I cannot wait any longer because I am thoroughly disgusted. I picked up this cpo'd 997 turbo yesterday and have spent the better part of today to try and figure out why it's not performing like I feel like it should.
With sport chrono on and psm off, the boost level would not rise above 9psi (doesnt feel that fast...doesnt plant you into the seat). Is this normal? Shouldn't it rise to 16-17psi..if only briefly. The car runs normally. If this is normal....i would rather have my m6 back. Thanks for all the responses on the previous thread. Additional input would be great. Thanks
Go and have the car dynoed, or go to the drag strip. Look for HP/Torque numbers or trap speeds. That will tell if it's your butt dyno needing calibration or something wrong with the car.
If the car happens to have a problem, you do not want to throw mods at it to cover up that problem.
I've driven a modded M6 and a Stock TT and the TT still felt faster and this was several months apart. If it dyno's right or traps right, then it's you, if not, get a diagnostic run.
It says your account is awaiting email verification. Check your email and see if there is something there to conclude the creation of your account. If not, create a new account and be sure that your email address is correct. You must verify your account and if it sent it to an incorrect email, you would never now!
As for the tech question, someone else will have to step in. I'm not a 997 owner, yet
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
if your only hitting 9 lbs you have a problem. ..and your missing out on the fun at the higher levels ![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
Get it into the dealer asap but worth while checking for lose fitting intercooler hoses, intake hoses etc. which is more than likely the culprit. You should see 14 or so in 3rd gear over 3k.
are there any idle or stalling issues? If so, it would indicate a boost leak probably at one of the intercooler hoses or at the intake Y pipe.
if no issues with idle/stalling, have them check the VTG actuator arms. They are supposed to be re-lubed to prevent binding which may keep you from getting full boost.
lastly, add some race fuel to the car (100-104 unleaded). These cars are very octane sensitive and if for some reason it was filled with lower octane (<93) you may not develop full boost.
If you are in Houston, take it to West Houston Porsche and as Don Irby to work on the car. He is simply the best Porsche dealership master Porsche Tech in the Southwest US
My advice to see if something is really wrong with this car, you should ask for a test drive at another dealership. This way you can compare with your butt dyno and decide your next move. If something is wrong with you car, you should definitely take it back to your dealer.
i drove an M5 with Gotham Dream Cars tour, and it definitely gives the kick in the pants feeling right off the line. The Turbo does have some lag, but at speed they should both be kicking hard. Good luck at the stealership.
There have been no idle or stalling issues, but maybe they filled it up with 87 octane. I will fill up and see if that changes things. I'm really close to North Houston Porsche, i'm thinking of bringing it by and having someone drive it. I was also thinking of taking it to auto dynamica to see if someone could drive it and tell me if it felt normal...idk(i believe they're in north houston)...any experience with them? THanks for everyones help.
I would avoid N Houston's service dept. They even screwed up their own sales manager's car.
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
