997TT prematuire rear rotor wear out?
Old 04-04-2009 | 06:42 PM
bill guinn's Avatar
Awaiting Email Confirmation
bill guinn is infamous around these parts
I have a 07 997TT which needs rear rotors after 26k miles. They are heavily grooved, and are near replacemenet limit, and the pads are at 1MM. Only one track day, which was actually well after the grooves formed.
This seems premature. Its is normal? The fronts are fine with at least 50% life remaining?
BTW where can I get OEM or good replacements without spending $1800 for Brembos? $1800 for Brembos seems excessive.
thanks
Old 04-04-2009 | 08:40 PM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
Red's or PCCB's?
Old 04-04-2009 | 10:02 PM
911rox's Avatar
911rox is infamous around these parts
It sounds like your PSM must be working overtime to contain the rear end... If you accelerate beyond the cars grip capabilities, particularly in the wet, the brakes are actuated to prevent spin. Would probably explain why the rears have worn at twice the rate of the fronts...
Old 04-04-2009 | 10:09 PM
GT3 Chuck's Avatar
Administrator
997's that track with PSM and have heavy foots are known for it
Old 04-05-2009 | 08:43 AM
TT Surgeon's Avatar
Typical for a 997tt, mine are grooved as well, I just put new pads on for now as they are still w/in spec. You can get a set of new rotors from suncoast very reasonably priced, I believe all 4 were like 800$ plus it's an easy DIY to boot.
Old 12-07-2009 | 05:50 PM
Zamir's Avatar
Zamir is infamous around these parts
Just came across this post while searching for rotor options. My rears (reds) are shot at 20K miles, and the front are still fine. Now I know the reason. This wont stop me from "heavy footing" the car. Instead, I'll just have to build more dollars in my budget to replace brakes more frequently!!
04-28-2022 12:38 AM
The_Ruski_Driver
10-25-2015 08:40 PM
awchristler
Bentley
08-24-2015 03:53 PM
TrackOne
08-20-2015 12:56 PM
Quick Reply: 997TT prematuire rear rotor wear out?
