Plug the tire?
I've had good experience with patch/plug on low profile tires in the past, though I had Firestone Tire tell me they weren't comfortable doing it, so I went to Discount Tire instead and ultimately had no issues with it. You should be fine as long as it's not near the shoulder of the tire.
Be very careful regarding advise on this issue. Street cars are often taken to 100 plus which could cause a tire failure. Not worth the risk cost in my opinion. Imagine if you had a passenger with you, even at safe speed, and a failure caused injury or worse.
What would the outcome be???
in conjunction with Porsche.
Interesting but scary side story. I was at a tire shop a couple of years ago when a guy in an SUV drives up with a flat tire. I then proceeded to watch as the grease monkey plugs a hole in the sidewall of the guy's tire. Freakin' unbelievable!
