Fried my PCCBs on the Track--- switching to Brembo GT
I apparently overworked the PCCBs on the track and cooked them. The aluminum heat shield melted and the internals of the calipers got fried and brake fluid was squirting around the seals and burning off when it hit the backing plate on the pads. Not good.
I had this issue before and Porsche replaced one caliper under warranty. This time, I cooked all four corners.
This time, they denied warranty due to my power mods (EVT 700) over-working the braking system. They also say I should have been using track pads. I appealed the denial, but they weren't budging.
Anyway, I didn't want to pay $6K for new calipers and then pay $5K/corner for rotors when they go, so I am switching over to the Brembo GT kit (Yellow calipers, of course).
Anyone else manage to destroy their PCCBs?
-Chris
-Chris
I bet you did a lot of hard braking.
<object width="425" height="344">
<embed src="http://www.youtube.com/v/VoPBSQFWXHU&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></object>
I have not experienced what you have but I haven'r driven my car at that level yet your post echoes what i had stated months ago . The PCCB is designed for a stock 997tt and with 700 Hp it would not be long before they fry .
BTW --I have been wondering what i am going to do with my steel brakes . if you want to buy them real cheap shoot me a PM and throw a price at me .
Otherwise you will love the Brembo.
PCCB is difficult to overhead, i believe they can handle much more heat than steel aftermarket ones, most probably you will fry the steel ones first time you track the car
We had the same problems on 997TT with PCCB using EVT 700 kit in Mexico. We changed for the Brembo GTR and these are simply the best.
I get front ABS engagement at what I think is lower overall deceleration rates as compared to the PCCBs-- but I acknowledge that this might be "in my head."
At 1/4 of the price (versus the new GTR kit), I think I will try the GT kit with 15" rotors on all corners and see how it holds up.
The "problem" with PCCBs is that they are so awesome at high heat that they give no feedback when being overworked. The rotor/pads/fluid all handle the heat fine, but apparently the weak link is the internal seals in the calipers. Extreme heat cooks them.
I am told that in steel brakes, they start to fade and otherwise give feedback "hey, buddy, you are killing me" and allow the driver to back off a bit.
Very interesting. I actually have the Brembo GTR kit (996TT version, however) on there now (free trial from Sharky---Thanks!). I don't like the look/size of the rear rotor and, although I haven't been on track with it, it feels too biased toward front braking.
Also, ABS will only interfere when you exceed the limits of the tires. If you are engaging ABS later with the GTR system it is simply due to the fact that the PCCB's may have had more initial bite. We can change pad compounds in the GTR system and achieve the same result.
Thanks for the encouraging words. ;-)
I just noticed that you mentioned you had a 996TT brake system on a 997TT.
The bias is in fact WRONG for that application and ABS functionality can and will be adversely affected. I do hope that this is not a permanent solution for your vehicle and you will be changing that sooner than later.
My previous post pertains only when using the proper brake system on the proper application.
