Fabspeed Intake in hot humid climate
I would say if you are seeing a temp. rise in Pittsburgh, where the temp and himidity is nowhere near that of Dubai. I would stay away of a intake, unless it blocks all air from the engine compartment. I agree with Gmoney about a better flowing filter. Until I see data proven different..
I have same intakes on the turbo. I put it for look and sound. The car in saudi and faces almost same climate. I don't drive the car a lot, but as long as i keep them clean with NO temp raise
Honestly.Not suitable for the summer.I am in NZ( southern hemisphere ) so the summer/winter time is opposite to US...I bought a set at OCT. last year (summer start).I used them for couple of weeks and found they are too hot during street driving.Not good for the engine.I then changed the stock air box with BMC filter back.I readed the intake temp. from OBDport and the stock airbox air intake temp. is around 10F lower than the fab intake after street drive on a 90F day.
Now it is winter here so I changed them back for some track days..
Thanks for the help. The engine bay looks great by the way.
I am still not sure what route to take. Problem is I drive my car everyday so I just have to make sure before I jump to anything. Some say the fabspeed is fine in the heat while others say it is not. Still not sure. Thanks all though.
I think I might just add in a bmc air filter to the stock box. However it looks very unrestricted. Looks nearly as if there are very thin gaps in between the filter lines. Is it something I should be worried about using in a dusty climate? or should it be ok if I clean it regularly? Thanks
The sound of the turbos coming alive is what I am really looking for. That is why I keep on thinking of the fabspeed intake. However I am now thinking of just adding a bmc filter to the stock airbox. Just need to be sure that the added dirt through the bmc will be safe enough to use in this dusty region.
But what i can't understand is that all systems similar to this, name it as ram air system. From my point of view, all this systems will have the same air pressure as in the stock airbox, unless you have some trunk scoops like GT3 for forced air (= Ram Air). Only this will increase the air pressure inside the airbox, and all the rest is fake marketing. I'm talking in something like this:
