Fabspeed Intake in hot humid climate
Hi everyone.
I was just wandering if the fabspeed intake with the heat shield is safe enough to use in very hot and humid climate. I live in Dubai and it can get really hot in summer. Is the new improved version containing the heat shield safe enough to use without getting heat soaked?. I ask because even when I leave my car to idle after spirited driving to cool off the temperature will nearly always rise a bit. This is probably because not enough cool air is getting into the engine bay fast enough. Would be worried about the fabspeed intake at stop and go traffic. However I just really want to hear those turbos whistling. If anyone has any input or experience with the fabspeed intake in similar climate conditions please chime in. Thanks for the help.
Hi everyone.
stick a high flow panel filter in the stock airbox and be done with it. open air elements are going to be hard pressed to match the stock setup as the weather gets hot and I will believe that until I see some testing data otherwise, I could be wrong.
Hi everyone.
In seeing how the snorkels fit over the cones (but don't create a seal), there appears to be enough fresh air that should come in. No doubt it's pulling a fair amount of hot air from the engine bay.
I for one did this mod for the sound, not for the performance. IMHO, as long as your temp guages are in the norm, no worries.
Keep the stockers just in case.
hi Im from dubai too, just keep in mind that any changes to the car, no matter how small, the whole warranty of the car will be cancelled. i read a post earlier, that porsche will deny the Whole warranty even if you change the rims. - so that you know. secondly make sure u know a good workshop. In the U.S there are many workshops who know what they are doing and u can easily depend on them, i cant say the same about dubai. What i suggest is that if u get the fabspeed intake make sure you put the stock back on everytime you take the car to service.
I just installed them last week. It gets hot and humid here in the summer. It's been in the 80's this week, and I've only noticed my oil temp running about 10 degrees hotter (though that's a baseline to much cooler days).
Well thanks for the help fellows. It seems that the only safe way is to go for a sealed box intake. I might just get the fabspeed intake and get some custome made surroundings put on.
Hah, yea I remember that topic with the dictionary thing. To be honest this intake seems amaazing but I am sure the cost is way too much. Thanks though.
save your money for other mod ,this one is not worth it ,if you still want one,i have one for sale.
for anyone who kept the stock, but changed to a higher flow filter...did you experience a significant sound increase in the turbo spooling and dumping sound?
it's an '09. no CELs. love...love the sound it makes. i'll update the forum if i find the engine temps in unsafe territory. was 85 today and had a fair amount of spirited driving...no problems.
