Lastest races of Switzer 997 TT SPI 750 !!!
#61
#62
If u noticed i mentioned it is 680hp kit plus his 100-200 6.5 which is as fast as FVD stage2 cars but the difference that the FVD car can beat F430 LOL!!
#63
There must be a problem with the Proto, i have just built mine (before had just exhaust ECU) the difference is very big. I also had the TCU done and the car changes gears a lot faster.
I also live in Europe and use 100oct pump gas, i never used any other fuel but i'll try to mix some race fuel to the 100oct pump fuel and see what happens, i can't imagine a huge difference
The diff btw 98 and 100+ is not huge...only 30-40 HP I think...
How does TCU feels ??? Car faster or not, did u measure it before and after ???
#64
#65
Your right man but this 997tt has first vtg's upgrade and reflash from Proto which made less power than newer kits of course
#66
i didn't do any before/after measure but the rev limiter increased to 7000rpm and the gear changes sound and feel faster.
Before i had exhaust/ECU and the car was hitting the limiter every now and then, especially changing from 1st to 2nd now i have the Proto 700 and TCU upgrade. Gear changes as very smooth on normal but a bit violent on sport i love it
I think its a must have for a modded tip
#67
#68
#69
#70
So since you can not do that, you should continue playing at Forza Motorsport
#71
Stop this BS please....We have runned against all German tuners here along with fastet one from Evotech and beat them all...even 9FF 760 build engine worths 80k Euro mods does high 10s here...
We have official record in 1/4 mile here aand no one came close yet !!!
We have proven facts and data !!!
You like your FVD car that is fine....talk about in another thread...
By the way, I've heard you are using 130 octane on those races as I've mentioned before, that does give you the head start big time. Hopefully we will get a switzer 750 kit and newest evotech 700 kit and try them with the same fuel, so we can see who is faster or who is not. You told your pump gas numbers and we can see that European tuners are faster with pump gas.I dont think the outcome will change if both cars use the same race gas.
#72
There are 3 members in this thread that are extremely close to getting banned. One of them, 997ttGuru, will be permanant since he has already been banned once before and this is his last chance.
I suggest you guys grow up and start acting like adults instead of acting like name-calling 12 year old school-children if you want to remain on this forum.
This is the only warning I will be giving you.
#73
Not impressive at all. We did 25.5 seconds 0-300 with FVD Stage 2. Us tuners kit are only fast on race gas, your numbers proved that we are right. I also did 9.3 seconds with 100 octane pump fuel 0-200 with my Stage 3 kit. You should be around 21-22 seconds (0-300) with 100 octane pump gas (which equals 93 octane us pump gas)to be considered as fast as european kits. The only programming (we looked into it) us tuners do, just select all the charts and raise it 4-5 degrees. Nothing special. I am not against any us tuners and bought some stuff from them, but we are trying to talk about true stuff over here.
" We did 25.5 seconds 0-300 with FVD Stage 2"... So u r as fast as $300k Ruf RT12 but ur FVD stage2 kit and only able to beat F430
" You should be around 21-22 seconds (0-300) with 100 octane pump gas (which equals 93 octane us pump gas)to be considered as fast as european kits "........AGAIN not with our pumpgas...Can't u get it?.. all 93's octane in U.S , Turkey/Euro and here ( Dubai ) DON'T HAVE EXACT SAME PUMPGAS!!!!!
" The only programming (we looked into it) us tuners do, just select all the charts and raise it 4-5 degrees. Nothing special "....Are u FVD tuner or customer ??
I don't giva a damn about ur numbers..Just like other ppl in here and rennteam coz u r test ur car on the pbox WITHOUT ANNTENA!!!
One more thing....I saw a 997 gt2 with FVD ECU, headers and exhaust lost to stock LP640...After some custom tune the same FVD 997 gt2 beat the LP640....DID U GET IT NOW??????
Last summer we took Proto 997tt to Switzer and also we got dofferent results on thier 100 octane pumpgas.....DID U GET IT NOW??????
U asked twice GT RUS if he ran 130 octane ...It is 103 not 130
Keep ur mouth **** before Scott get pissed now...Can u ?
I'M DONE SCOTT!!!
#74
#75
ESPECAILLY FOR EURO tuners LOVERs and NON BELIEVERs....
Vid from 1 mile EVENT....SPI 750 vs Edo competition 650 !!! everything expect IC...TipS vs Manual !!!
1 mile run
http://www.youtube.com/watch?v=lQUzk...layer_embedded
1 mile run
