Seatbelt Help, is there a twist in yours?
Had my front seat belts installed this past weekend and I'm not sure if I'm remembering incorrectly or if the dealer installed them incorrectly. Both of my seat belts do not lay flat anymore but have a twist in them and the manufacture sticker is facing the pillar so one can't see it when not hooked up. Just wanted to make sure that they didn't goof up on this since all of my other non-porsche cars seat belts lay flat when not installed.
Hope this isn't too confusing....
when it is unbuckled and laying flat against the side pillars, mine has a twist in it and the tag is facing the pillar. if i unscrew the bottom bolt and flip it so the tag faces away from the pillar the twist will be gone. so should have the label facing away from the pillar towards the seat or is the twist suppose to be there? so confusing....
This was one of the first things I noticed when I got my car. I told my salesman it had a twist in it but we looked at a couple of other ones and they were the same. Does not seem correct but it is normal.
cgunsch
11
11-27-2015 11:20 AM
bongnation
09-25-2015 02:58 PM
