Rear spoiler not working properly
Hi,
washed the car tonight and like to raise the spoiler so i can give it a good clean.
Noticed the left side of the spoiler had not deployed fully, however the right hand side was fine. It goes back to the fully stowed position with no problems. Tried it a few times with the same result !.
Anybody seen this before ?. Whats the general consensus on the fault ?.
Will be dropping the car off at the workshop tommorrow for rectification.
Rgds.
Rgds.
Hi,
Rgds.
Rgds.
PITA to bleed the system. Let your dealer do it if it is under warranty.
The other thing you may want to check is that the hydraulics are not actually damaged...a loose bolt can be tightened, but if the tubing has a hole or leak, they may need to be replaced. The dealer will be able to tell.
Good luck!
Mackchacha
07-09-2019 11:03 AM
3WDistributing
31
10-27-2017 01:26 PM
r_matt_6
10-08-2015 06:07 PM
