LED Lights Installed on a White 997 TT
#46
only the hoens did not because they say they use a 2.7w tiny resistor built on to the led bulb heat sink which is enough to satisfy the system while allowing the led to run cooler than stock. You may want to get with those guys in solving the problem with the white led bar conversion as with that solved that product will be a hot seller.
#53
Give me some time guys, I want these back on my car with no warning light issues too! I am also going to build a harness so they are connected to switch power so they are true DRL, not turn your lights to the on position type.
#54
that may be the best approach, wire into the fuse box, there are unused sectors that turn on with the ignition (like what I used for the radar install). That way you dont worry about bulb out warnings and it turns on with the car. The low voltage should be fine, stick a nominal fuse in its place and your golden.
#55
