Damptronics question
My stock shocks are done, looking at some billsteins.
What is the difference between B16 'spor't version and the 'comfort' version?
all i could find would tell me that there is one set up, and that with our electronic adjustable suspension you can switch between comfort and sport
dont know if this is right, all of the bilstein stuff i saw was in german
below is a thread with some suspension recs via sharkwerkes, just an opinion:
https://www.6speedonline.com/forums/...ronic-gt3.html
all the best TT surgeon...
Sportsuspension B16 damptronic, FA+RA 15-35mm CLUBSPORT/
Only for cars with PASM!
GA5-D581 Sportfahrwerk B16 damptronic, VA 25-35mm, HA 15-35mm / P97 C4 / Turbo 1
Sportsuspension B16 damptronic, FA 25-35mm, RA 15-35mm /
<o></o>
The 3<sup>rd</sup> listing are the D598’s (which I have fitted to my car), the last list is the D581. I would recommend -15mm drop front and rear for the D598's, any more than this and you will be losing teeth
For what you use your car for, I would not recommend the D581's at all.
We have coupled those with H&R coilovers on our in house car.
It's a great set up for double duty cars.
Nice one Mike - I also wondered about that, thanks for confirming with Bilstein.
Hey whilst we are on topic. Ride heights for B16's dictate how much travel they have in the dampeners and thus how hard/soft the ride is.
Those D598's I have fitted, I set mine to the minimum drop of -15mm. However as the new suspension has settled (read sagged) I have been able to adjust the dampeners back up at least 10mm and still be at -15mm from stock (in red below) with the ride softening each time:
F=132 +/-10 --> 117 mm<o></o>
R=153 +/-10 --> 138 mm
So my question is, are the Bilstein recommended drop range more to do with car dynamics or are they more to do with dampener travel ie. you shouldn't set the dampener to have too much travel in them... I am just wondering if I can keep repeating this procedure over time (obviously they will plateau at some point) and make the suspension softer each time without going past any Bilstein thresholds?<o>
</o>
</o>
F=132 +/-10 --> 117 mm<O></O>
<O>></O>>
<O>></O>>
Damper travel...
An OT question. How many miles did your stock shocks last with lowering springs? I'm thinking about doing springs but don't want to break my stock shocks down the road and end up having to do coilovers anyway.
But I want it softer ie. higher ride height, not lower (so no chance of stack bottoming out). I find -15mm still too harsh for bumpy UK B-roads. And I don't want to go higher than -15mm if I can as it also helps the center of gravity and thus handling.
So I want to know if I can keep adjusting the B16's upwards whilst my car sags downwards, thus keeping the same ride height - and it not damaging the B16's in the process...
They really don't offer choices, but in their technical drawings there is an acceptable range where you can go either up or down on the spring rate. IIRC, the spread is 135Nm.
Bilstein's recommended drop and ideal operating range for the Damptronics are as follows:
F: 10-30mm
R: 5-25mm
Err no Mike I believe those values you just posted are incorrect - see my screenshot at the top of this mail from the Bilstein site. The recommended range is -15mm to -35mm for the D598's. Unless you know the unofficial ranges.
So my question was is that range for dampener travel reasons (which I suspect the -35mm is so you don't get bottoming out) or for car dynamic reasons (which I would expect the -15mm is).
You are in the UK, so I would not be surprised if the specs are different for ROW applications. The U.S. market is unique and it is not uncommon at all for Bilstein parts to have varying specs.
What I should have done is clarifed and said that those were for U.S. spec kits sold here in the States.
I understand where you are coming from now. The answer to your question is both.
Thanks Mike. I find it odd that for the same car and parts that Bilstein specify 2 different ranges on this web sites depending on what continent you are in. Those 15-35 specs were from the European International Bilstein site.
