Clutch pedal almost floored, no disengagement
In the past few days, the weather in Utah has turned. I noticed the clutch was engaging much lower and the pedal wouldn't fully rebound. This happened more and more when the car was cold. This morning, the clutch was all but two inches off the floor, and wouldn't go into gear from idle/nuetral. Porsche roadside picked it up and took it to me dealer and am waiting to get word.
Has anyone ever experienced this symptom? car has 25000 Miles and is mechanically stock besides tires.
It's the clutch slave, I'm on my 2nd one already. First one went bad at 800 miles, and the 2nd one started to push fluid back out the reservoir last month at 4500 miles. Porsche apparently came out with a new clutch slave. I got the new part installed 2 weeks back, and so far so good. But the clutch does feel different than before when I step on it now.
I just compared my service orders, they both show 996-116-237-52 as the part number. But I actually went back to the dealer after I got the car back this time because of the difference in pedal feel. I was talking to the tech who worked on my car for a while, and he assured me a few times that the part is completely different than the old part.
thanks for all the input. I'll be providing this to my dealer for review. Please post up anything else you think would be useful for my tech to see. The senior tech there is one of the best, and the mid level guys have been around for a while too, so I suspect they know the problem perfectly, but you never know.
clutch problem
This exact scenario just happend to me. The car is at the local dealership now, sure hope its only the slave. Does anyone know if Porsche has developed a better part to fix this problem?
There were three cars at my local dealer with this issue, mine is still not fixed either, its losing fluid but no leaks on the floor. Im holding off until a fix exists and I get firm data backing it.
The tech told me straight out the Porsche guys want the cars turned around asap to avoid lemon laws as its happened numerous times in the last 3-4 months. There should be a recall on this, absolutely.
The other day my clutch was rock hard, needed fluid. I limped to the dealer and had them top it up, all was well.
Where is the fluid going??? Kind of scary and alarming. Is there something we can complain to the feds about as clearly its a danger to some degree and force a recall that way? Sounds extreme sure, but not to those who are dealing with this 2 or 3 times.
andbos
09-07-2015 07:13 PM
