Autoweek review of PDK/turbo
Interesting... the added power came from DFI, larger block and higher compression ratio. The turbos are now maxed out at 11.6psi vs. 14.5psi on the current 997TT.1.
Do I smell a "turbo S" in the works?
For the new 911 Turbo, however, there are changes to the nominal torque split to provide what Achleitner describes as a "more tail-happy character." Porsche has changed the software to allow the multiplate clutch to send a greater percentage of drive to the rear under a wider range of conditions.
Read more: http://www.autoweek.com/article/20091013/CARREVIEWS/910139990#ixzz0U1AqtjPK
How good is the handling? According to Achleitner, the new 911 Turbo will lap the Nürburgring in 7 minutes, 39 seconds on standard Bridgestone Potenza tires--some 10 seconds less than the time quoted for its predecessor.
If this new turbo is 10sec faster than the previous turbo, then it should be 7:28.
Something is fishy...
Looks like the factory aero kit to me...
Imagine yourself behind the new three-spoke steering wheel of the new 911 Turbo at the end of a long and flat straight. You call up the Sport setting to active the dual-clutch gearbox's launch control. With 5,000 rpm wound on the engine, you sidestep the brake and are launched with incredible intensity--the sort that sends your head careening back into the headrest and your stomach wishing it was somewhere else.
hahahahaha, I find this to be true every time I hit the gas and I don't need PDK.
Interesting... When I built my 550HP 944 Turbo, we had to reduce the compression ratio by using a thicker head gasket to bring it down to 8.8:1 that was the only way of running more boost, otherwise we ran into detonation issues even with 104 octane race gas.
It's going to be interesting seeing you aftermarket guys working on this new engine... It looks like it will be more complex than any previous generation.
Lowering your compression ratio was needed to deal with less efficient spark control and fuel atomization, which could result in localized hot spots in the chamber from uncontrolled combustion, which in turn could burn a headgasket, valve, or piston, or rock a piston so hard it could break rods or cylinder walls.
Getting control over the combustion process means the compression ratios can be raised.
DFI is already here on the NA 997, and we've been adapting to it with the VW and Audi vehicles since 2006. It is immensely complex, with mechanical operating tolerances never before seen in passenger cars, but we have a boatload of experience with it already.
What concerns us more is that the new turbo is supposed to have the GT2 style "expansion" intake manifold, which uses increased boost from the turbos to create a cooling effect with a expansion chamber right before the intake valves. That higher boost reduces the headroom we have to work with in increasing performance, and is why we don't currently offer a 700+hp kit for the GT2 without retrofitting 997TT parts. At best, we can retrofit 997.1 TT intake parts to the 997.2 TT, which still requires and engine drop. At worst, we need to design our own replacement parts.
Either way, our turbo was ordered in September and we should have one of the first ones to hit the US...
Modern fuel injection control is amazing these days. Add the extra fuel delivery stability from DI, and the chance of damaging detonation goes down dramatically.
On the surface, this industry looks like a ton of fun.
What goes on in the background, from unconventional industry standards, to massive investment with little payoff, would probably change your mind.
This is an industry driven by egocentric emotional demand for the most part, but subject to the same rational economic laws as any other industry.
In a lot of respects, it like the Wild West.
What do you do? Maybe we can change places.
One of my friends is a guy named David Raines.. he was the owner and founder of PowerHaus in AZ.. Trust me, I know what a bunch of whining, entitled, prima donnas us customers can be.. I don't know how you guys put up with us..
