best lowering springs to put on a cabTT
My car had the Champion springs. The ride was great. That is not the issue. The tt has a frotn lip that goes out horizontally, almost 90 degrees unlike say a Cayman were the nose goes slightly up. I had springs also on my Cayman which now has coil overs. I never scraped with the Cayman however the tt scraped everywhere. The drop and the low, far reaching lip will be an issue. I switched back to stock springs and will go will coilovers and a mild drop of about 10mm. Most springs will drop your front by 1 - 1 1/2 inch or 25 - 35mm. I have my Champion springs for sale on ebay. I suggest you see the drop in person on somebody's car and even better get a ride.
I also changed to the Bilsteins at a minimum drop, the ride is similar and the scraping is now virtually a non issue.
HRs DO sag overtime, so be careful. Only the gmg springs will not sag, they drop exactly 20mm, no more no less. I never scraped with those, now with the bilstein they seem to have settled and now I'm scraping all over
I'mAllIn
09-11-2015 06:38 AM
ECS Tuning - VW
08-26-2015 12:33 PM
