Keithta - New Record 60-130 mph Times - Graphs Posted - 997/911 Porsche Turbo 3076R
#32
But as for 3rd, 4th & 5th, here is something for reference:
Once boost comes in 3rd, that gear was blasted through in 1.66 seconds....upshift into the next gear and holding 4th out finishes in 2.3 seconds. 5th is a longer gear but surprisingly once engaged into 5th, the Scan XL file shows us hitting redline in 5th in 3.3 seconds. I looked at 2 files showing time spent in 5th gear after the 4th gear upshift and they both seem to show 3-3.3 seconds.
If you actually count that out in your head and imagine shifting through the gears you will see how ludicrous these cars start getting at these power levels. I still am baffeled about how fast this thing pulls through the gears - it really feels like its out of control............but then again this has been the fastest car Ive owned so I dont have anything else to compare it to....
Here is a G force graph from the driftbox during a 2nd gear pull (50-70 mph)
Boost was set to 1.7 bar on this run
I was on my 20" wheels with traction control on. Did a 50-70 mph pass from 2nd gear. I clocked off a 50-70 in 0.68 seconds.
More amazingly, it pulled 1.674 Longitudinal Gs of force right when boost came on and dropped off to 1.16 Gs by 70 mph.
50-60mph - .32 seconds
60-70mph - .36 seconds
Here is the graph: I Left the cursor on the peak Gs for that run so you can see the numbers. I tried this run again with a little more boost on 19" wheels but my tires wouldnt hold.
#33
The power related mods are: Prototech Exhaust, Standard non-modified GT3076R with .63 ARs, Stock Headers, 4.5" Proto Intercoolers, Proto Air Intake & Y Pipe, Custom Intercooler and Inlet piping, 80 lb Injectors, Custom programming, everything tuned for MS109 fuel.
#34
#37
Congrats again!
#39
any reason that you go with stock headers instead of protomotive? and any motor work besides the cams? 1.7 seems a bit high for me even with ms109 on stock motor.
#40
PMing you now.
Keith
#41
Even Divextreme's old 996tt maintained the stock headers well into the mid 800 whp range with GT3076 turbos. His car ran like a bullet with the stock headers.
Switzer has run the 997tt up to 2.3+ bar on the stock motor. I know thats quite crazy but it just goes to show the abuse these motors can handle in stock form when tuned correctly.
I have played with boost levels higher than 1.7 bar with ms109. Compared to C16, The weaker properties of MS109 fuel starts to show up in the form of some knock around the 1.7 bar range with most of Todd's MS109 997tt tunes. If you plan on running more boost than that, he would send you a custom tune and may need to make some alterations to your fuel system.
Above 1.7 bar larger injectors and more carefully calibrating timing curves come into play. Also Air fuels need to be fattened up. You can run quite a bit more boost with MS109 - as long as your tune is in line.
I was running a fuel pressure gauge in my car during my tuning runs and kept turning the boost up in an effort to see where the fuel pumps would start to run out. Surprisingly, the stock pumps are still keeping up and the pressures were still holding....although, Im sure Im right at the edge.
I was contimplating running C16 to keep things cooler and safer but scratched that idea when I figured Id be going through new sets of spark plugs every 1500 miles or so. We all know that changing the plugs on our cars is not fun and is expensive as hell. Not to mention O2 sensors would be fried left right and center. Everything inside your motor would develop lead build up - something I didnt want to contend with. Id rather sacrafice some power and run a more conservative MS109 tune then getting C16 performance and have to live with the problems & the expense leaded fuel brings.
#42
Thanks! Yeah.....Cant believe its been about 2.5 years since I got rid of my M6. Remember the video of my modded M6 vs a stock C6 ZO6 45-195 mph? http://www.youtube.com/watch?v=9_QpKNozKN0
#43
Here is a run running against the same ZO6 with my Porsche from almost 2 years ago. I ran 1.25 bar with 103 octane fuel 60-130s were 6.4 at that time. Maybe 150-200 whp less than the car sits now.
http://www.youtube.com/watch?v=PRvrOMgau4k
#44
With the new kit you have to race a gixer for us to see the difference
