Outlets not working??
Old 02-19-2010 | 09:13 AM
996TTer's Avatar
996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute
Hi,
it may be a stupid question, but I have 3 power outlets in the car, the cigarette lighter, one in the armrest and one in the passenger foot compartment. For charging my cell only the cigarette outlets works. Is that normal or am I missing something here?
THX
Old 02-19-2010 | 09:19 AM
joecmess's Avatar
joecmess is infamous around these parts
Check your fuses
Old 02-19-2010 | 01:02 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
same here. I checked the fuse and it's good. Don't know what else to check. The one in the footwell on mine doesn't work.
Old 02-19-2010 | 02:34 PM
996TTer's Avatar
Originally Posted by joecmess
Check your fuses
All fuses are fine I think, any idea which fuse is for the armrest and passenger side outlet?
Old 02-19-2010 | 02:47 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
The fuse for the footwell is a different amp, notorious for blowing.
Old 02-19-2010 | 03:02 PM
NeilM's Avatar
according the fuse diagram, there's only 1 fuse that corresponds to both 12v outlets. it's located on the first row...I believe it's fuse #8 (7.5v).
Old 12-13-2011 | 01:01 AM
DS997c2s's Avatar
DS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to behold
I noticed the same on my non-turbo 997.1, the one on the footwell and in the mid console don't work. Will check on fuses. Hopefully I will have a spare to use.
Old 12-05-2014 | 02:34 AM
Verone24's Avatar
Verone24 is infamous around these partsVerone24 is infamous around these parts
I noticed that it shows D5 as the cigarette lighter fuse.....is there another one for the one in the armrest and the footwell?
Old 12-05-2014 | 10:01 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Has to be the fuses. I had the same. Used a volt meter to test zero power. Pulled the fuse panel and found the fuses were missing.
Old 12-27-2014 | 04:33 PM
Verone24's Avatar
I checked #8 and #10. still no power to both the passenger footwell and arm rest
Old 12-27-2014 | 05:06 PM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
I know the footwell plug has less voltage. Plugged a tire pump in that and it instantly blew. Cigarette lighter is 12v
Old 12-27-2014 | 05:20 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Maybe this will help....At least to identify all your fuse operations.
Good luck,
DC
PS...Depending on what you are plugging in to determine it has no power?? Some of the Cig plug adapters have an old glass tube fuse built in and they blow quickly...Just a thought.
Old 01-02-2015 | 01:03 AM
Verone24's Avatar
I tried 8 and 10 still no luck
Old 01-03-2015 | 09:27 PM
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
Have you inspected the outlet itself? Maybe its defective (ie a wire came off)?
Old 01-03-2015 | 09:40 PM
Verone24's Avatar
yup inspected both the arm rest one and the footwell one. I already replaced #8 and #10 fuse
