New clutch required?
#31
To those who've tried LWFW (and of course, the pro Mike/AWE): we've talked about noise, but how does the LWFW affect the feel and ease of clutch engagement please?
If a LWFW changes speed faster, doesn't it make engagement more difficult?
Thanks for this great discussion. I finally "get it" as far as which clutch to buy.![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
#32
#33
The engagement point is nearly identical to the stock flywheel, which you know is pretty high compared to other vehicles. The engagement "range" is slightly shorter, but you can still modulate it to inch the car forward up a hill.
There are several that have them on the 996TT that use a clutch stop to make the travel length shorter.
That's the best I can do without having you drive my car (which you are welcome if you ever decide you like the snow
- bob
#34
I have driven a myriad of cars with and without flywheels. Especially on the modern Porsches I don't feel a difference on engagement or modulation if using a clutch plate and disc combo that was similar to stock.
#35
+1 ^^ My experience is limited since I've only driven one. The engagement was high up and found it difficult to modulate. It would take a bit of getting used to as GB said. I don't exactly know what set-up it was but my 2.5 set-up feels like stock, perhaps a little better since you can also feel a more defined clamping, especially in 2nd gear which never felt great.
#36
Gene seems to indicate in one of his posts that he uses the stock clutch disc, instead of the Sachs xxxx973 clutch disc?
Could you comment on this please? What's the advantage/disadvantage of re-using stock clutch disc versus xxxxx973? TIA
BTW, Tom (of Lucent) keeps telling me I need to replace my clutch. When I drive, nothing happens, when he drives, immediately the clutch slips. Hmmmm. I don't dare to ask him anymore how he test drives my car.
![EEK!](https://www.6speedonline.com/forums/images/smilies/eek.gif)
![Stick Out Tongue](https://www.6speedonline.com/forums/images/smilies/tongue.gif)
#37
There is a modification to the clutch if the engagement feels too high...
You can remove the slave out from the transmission and pull the pin out and cut it to move the engagement point lower.
#38
I will have to call Gene to get a clarification since I sold him the 973 disc along with his 764 plate.
#39
I could be a little overly sensitive, but that is what I have experienced. I think for me, the quicker throttle response affects my ability to modulate the shorter and higher engagement point of my setup. The engagement point is definitely higher than stock.
#40
What you are talking about is the height at which that happens. I understand now.
Ok, I have noticed it slightly higher, but as for what I was calling "feel", that has not changed with or without the flywheel.
Simple misunderstanding. We are on the same page now...
#41
Thanks for all the great feedback guys - very useful thread!
I took the Turbo out this morning and tried to replicate the slipping clutch. Temperatures were between 5-7 degC. In 5th gear and below I couldnt get any slip no matter what I tried. In 6th, with full acceleration from 60mph with overboost (1.2 bar) on a flat motorway - nothing.
So it seems that only at 50mph in 6th gear do I get clutch slip. I can still smell the clutch from last week when I did it though!
So I'm not so sure I need a new clutch right now after all. I think if it starts slipping more often then a Sachs stage 2 clutch with the OEM dual-mass-flywheel will be required. If I was going to move to a single-mass-flywheel then I would upgrade right now as it would be a performance enhancement. But for just a functional upgrade, I think I can avoid 50mph 6th gear runs in cold temps for daily drives and stick with OEM
#42
Alex, and thanks for starting the helpful thread.
As far as the clutch slip, 60 mph in 6th gear is about 2300 rpm? I am no expert but I think the clutch would be more likely to slip at a much higher rpm. Why? Because you are looking for the point where there is maximum torque on the clutch, causing it to slip. In our Turbo this would be above 3000 rpm, where the "power explosion" occurs. More specifically the torque plateau of our Turbo's is around 3300 rpm to 4300 rpm range (depending on which dyno but this is the general range).
In my car, I vaguely remember it was 4th gear around 3800 rpm. The needle just slips from 3800 to 4800 rpm without any speed change in the car. Anyone has anything to add to this please?
#43
#44
I got my first clutch slip today in 6th gear with an ambient temperature of 7 degC. I floored it with over-boost off (1.0 bar) from about 50 mph. I couldn’t get it to do it again even with overboost (1.2 bar) in 5th gear downwards.
I can still smell the burnt clutch an hour of driving after it happened.
Does this mean I need a new clutch or is one clutch slip no big deal? Saying that, I did have a similar thing reversing up a steep hill back in 2008 in Switzerland, the smell lasted for about 20 mins then.
I know I have 798Nm torque with my CG544 kit which exceeds the factory clutch tolerances; perhaps I need a whole upgraded clutch kit?
Eg. Cargraphic Clutch
Or perhaps just an upgraded pressure plate?
My car only has 17k miles on the clock so I would rather not change the whole clutch out unless I really need to.
Would appreciate your thoughts...
(also opinions on single mass flywheels please as part of that kit mentioned above)
#45
