New clutch required?
#106
Anyone know what setup the new 997.2 GT2RS has?
-saying that the GT2RS only runs 700Nm torque dispite it having 620PS power.
#108
I just bought the Stage II.5 Sachs kit and was wondering which set of bolts I need from the picture above (i.e. the black ones or the silver ones). I presume it's the black ones to join the pp to the flywheel, right? I'm sticking with stock flywheel.
#109
Alex, and thanks for starting the helpful thread.
As far as the clutch slip, 60 mph in 6th gear is about 2300 rpm? I am no expert but I think the clutch would be more likely to slip at a much higher rpm. Why? Because you are looking for the point where there is maximum torque on the clutch, causing it to slip. In our Turbo this would be above 3000 rpm, where the "power explosion" occurs. More specifically the torque plateau of our Turbo's is around 3300 rpm to 4300 rpm range (depending on which dyno but this is the general range).
In my car, I vaguely remember it was 4th gear around 3800 rpm. The needle just slips from 3800 to 4800 rpm without any speed change in the car. Anyone has anything to add to this please?
#110
Yes and it only get worse with time...eventually can't accelerate at all with out
constantly approaching red line at modest speeds.
Since New York has become a "1984" police state I have found any speed above 50MPH to be dangerous any way...but
I won't have a choice but to get at least a pressure plate soon.
#112
Finally got a new clutch after slippage became a frequence occurance.
Went with the Cargraphic reinfored clutch with single mass flywheel
The single mass flywheel certainly revs quicker, but I REALLY don't like the car sounding like a bag of nails in the engine when you accelerate from under 2000 rpm
jaehoppa
10-22-2015 09:17 PM
09-03-2015 04:56 PM
ECS Tuning - VW
09-03-2015 09:43 AM
