gt2 engine mounts
gt2 engine mounts
I am taking a different approach as i dont track my car much , mostly spirited driving. Instead of going with wevo or rs mounts , I was thinking of using gt2 oem mounts on my 997.1 tt. i checked from renntech / loren that it is a motorsports part # and all the hardware for both cars is the same. theoratically it should fit but not sure. can somebody with a 997 gt2 take a pic of the engine bay with the mounts. i want to see what they look like. much appreciated
I101 is PET code for the GT2:
Why do you say that smr, have you tried it out, its definatley a differnt part # and it ends with a 91 and I was told that's motorsport part. I am talking about a 997 gt2 part #
So i removed the turbo engine mounts and installed the gt2 engine mounts, they were exact fit and as i suspected the turbo mounts were soft i could move the shaft with my hand, and ont the gt2 mounts i could barely move the mount shaft. so it is confirmed that the gt2 mounts are motorsport part #. (stock look) so it is lot stiffer then turbo mounts. waiting to install the exhaust . will keep posted about the drive feel.
i am sure i will feel the difference as well because as mentioned before the turbo mounts were soft the shaft was movable by my hand power, i thought about the rs mounts , but i opted with gt2 as it was a direct fit and stiffer then turbo. so we will se. ruf_turbo can you tell me where you saw the difference so i know what to look at. also do you think chassis reinforcement is required when you put stiffer mounts.i read in other forums that it was, not sure about 997 chassis?
i am sure i feel the difference as well because as mentioned before the turbo mounts were soft the shaft was movable by my hand power, i thought about the rs mounts , but i opted with gt2 as it was a direct fit and stiffer then turbo. so we will se. ruf_turbo can you tell me where you saw the difference so i know what to look at. also do you think chassis reinforcement is required when you put stiffer mounts.i read in other forums that it was, not sure about 997 chassis?
I never heard anything about chassis reinforcement when I talked with Wevo or my dealer (Suncoast) about installing the mounts.
The backend of the car just felt more planted, more solid with the RS mounts. You could rev the engine with the stock mounts and see the car 'motor torque'. With the RS mounts there was no movement whatsoever.
i wasnt aware of that , what is your def of hard launch. thanks for the feed back, is it that bad you want to change to stock mounts? thats one of the reason i opted with gt 2 mounts as they are still hydraulic , but lot stiffer then turbo. we will see how it performs.
