best "air-cool" sound exhaust for 997 Turbo
FVD is the way to go, I'm in the process of changing from my TUBI street to the FVD export system with Titanium tips!!
I found the TUBI to be alot more higher pitch than the FVD vids and the fitment and construction of the TUBI was bad!! IMO
Hello,
I recently purchased a 2007 997 Turbo and I find the exhaust note a bit quiet. Can someone tell me what would be the best after market exhaust system to create the "air-cool"sound? I am thinking about Ruf/Tubi/Cargraphic
I replaced the exhaust of my previous 996 C2 with Fabspeed and found the resonance quite annoying around 60mph and up...
Thank you so much for the help
Lawrence
Lawrence
Exhaust is a hugely personal decision. After lots of research, I went with the Tubi Street. Night and day when compared to stock. I have no resonance issues at all. Wanted a nice exotic sound, but not overly loud as I have a cab, and sensitive neighbours. I can't tell you how thrilled I am with it. Never even turn on my radio anymore for fear of missing some of the exhaust sound. Even when it's really cold up here (Toronto), I always drive with my rear side windows open so I can hear more of the beautiful sound. Whichever way you go, it will be better than stock.
Good luck!
Good luck!
Good luck!
Good luck!
Try something different. A bunch of us Southern Cali 6speeders are running the new BBI Autosport exhaust and we are absoluetly in love with it. The sound is absolutely different from any other 997tt exhaust out there. It screams like a NA motor at WOT and has absolutely ZERO drone.
Sounds great and would love to see it/hear it and am sure its good, but honestly I could not possibly imagine it to be any better than the Europipe as its just had too much time and effort put into it. Also, i dont buy the bit on the "absolutely zero drone" (no offense Gotboost) as the stock exhaust still has a bit of its own so again cant imagine how any A/Mkt exhaust can manage to give a decent exhaust note and at the same time completely eliminate the stock systems own boom. Its simply just not plausible. The "zero drone" thing is BS and that needs to be accepted across the wider community. It is acheivable on an atmo engine but this 997tt VTG engine.....no way can it be totally eliminated. Thats not to say i wouldnt like someone to do that.....it evidently appears to be impossible given the stock mufflers own predicament.
The BBI system is a truly a fantastic piece of hardware. Sounds great, significant weight-loss. But drone IS there, but it is VERY tolerable. Particularly at around 2100-2300 rpms on throttle where most systems suffer from this problem. There is no perfect system out there, but I'll throw another vote in there for this as one of the best.
Europipe EP1 quality is amazing! Absolute perfection in my opinion.
With respect to all others on this very well worn subject, as the OP has already experienced drone and doesnt want any (or should i say want the least possible for this engine) then there is definately only one option out there and thats Europipe's EP1. Yes you will pay more for the EP1 over the others but there is a reason why. It just depends whether you want to find out the easy way or the hard way. The 997tt engine already has a bit of boom in the stock system between 1700 and 3000 under load so dont delude yourself that will get any quieter. EP1 will not only give you the least possible drone (like stock), but an awsome sound (way loud enough) and your butt dyno will definately feel it has clearly woken up the engine. Highly recommended! Dont blow it!
Speed, you're absolutely correct. I always thought I was a bit sensitive to it, but the stock exhaust, while anemic, did have a bit of a drone.
Good luck and more to the point....enjoy!!
sounds great and would love to see it/hear it and am sure its good, but honestly i could not possibly imagine it to be any better than the europipe as its just had too much time and effort put into it. Also, i dont buy the bit on the "absolutely zero drone" (no offense gotboost) as the stock exhaust still has a bit of its own so again cant imagine how any a/mkt exhaust can manage to give a decent exhaust note and at the same time completely eliminate the stock systems own boom. Its simply just not plausible. The "zero drone" thing is bs and that needs to be accepted across the wider community. It is acheivable on an atmo engine but this 997tt vtg engine.....no way can it be totally eliminated. Thats not to say i wouldnt like someone to do that.....it evidently appears to be impossible given the stock mufflers own predicament.
No. Vivid does not carry EP. At least they didn't when I checked with Dan a couple of weeks ago.
I'm not sure what you mean by software need...
If you are on stock ECU, you will still get the most/all of the benefits of the new exhaust without re-flashing.
If you've already re-flashed the your ECU, you will not need to re-flash it/tune it for an exhaust change but you will get noticeable improvement with this combo.
Having said that though, ECU upgrade + exhaust upgrade + air filter upgrade always work very well together and I think you'll find that their is a consensus here that they are a great stage 1 performance upgrade package.
Good luck.
Good luck.
As far as the BBI system being better or not to Europipe is all subjective I guess. However, don't doubt something you haven't heard yourself. I have heard both and I personally prefer the sound of the BBI system myself. Cost between the 2 aren't that different, so you can't use cost as a basis for what is better or not.
