Sponsored by: Bears Transport
GT3076 .63 ars
Old 03-13-2010, 08:27 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
GT3076 .63 ars
do i need to upgrade the fuel pump and the injecters if i have GT3076 ??
am running stock fuel pump and never upgrade the injecters
thanks
yousef
Old 03-13-2010, 09:28 AM
Dick Fidd's Avatar
Dick Fidd is infamous around these parts
Sorry I don't have your answer, but another Q - do you know the spool(rpm)/power difference between a .63 and a .82 A/R on a 997 GT30 car? I imagine you considered both options, so you may know off the top of your head... thks!
Old 03-13-2010, 09:42 AM
MorePSiTehBett4's Avatar
MorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really nice
higher a/r = more top end power in sacrifice of spool
Old 03-13-2010, 02:51 PM
Dick Fidd's Avatar
Sure but how many RPM difference for full boost, and any loss of power at lower RPMs? I'll check around for a dyno with the 2 turbos plotted against each other...
Free bump for the original poster - and sorry for the hijack.
Old 03-13-2010, 10:55 PM
ysfg35's Avatar
Old 03-14-2010, 04:40 AM
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
should be around 200 rpms.
Old 03-14-2010, 10:33 AM
can't really say without firsthand experience but 200-500rpm should be the window and obviously setup dependent as some cars respond differently(but that's another debate).
Old 03-15-2010, 08:37 AM
keithta's Avatar
keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !
Hi Yousef.
The factory injectors in the 997tt were tested with the GT3071/.63 ARs to 1.65 bar where they were at 100% duty cycle on MS109 fuel. Anything higher you will need to step up the injectors a set that flows more. Go with 80 lb injectors. The factory pumps are strong on the 997tt and ave been tested up to 2.1 bar without running out of fuel pressure even when running the Gt3076/.63 ARs.
Never tested the GT3076/.63 ARs but the boost level will be close to that - maybe a little lower. If you are running GT3076 turbos, to be safe I would upgrade the injectors at anything over 1.5 bar.
If you have a Durametric cable and their software (get info on this at durametric.com) (you can pick up one of these cables from Todd @ Protomotive) you can run a data log while you are under full throttle at various boost pressures and watch your injector milliseconds and see when they are at 100% duty cycle. Start your test at 1.4 bar and work your way up in .1 bar increments until you reach 100% on the injectors. Once you find the max limit, turbo down the boost by .1 just to be safe and thats where I would run the car.
What boost pressure are you running and whats the config of your turbo now - still the same?
Keith
thanks
yousef
Old 03-17-2010, 09:25 AM
ysfg35's Avatar
Originally Posted by keithta
Hi Yousef.
Keith
thanks bro ...
in fact am going to boost 1.6 this time ,, so am afraid that i need big injecters .. thats why i asked to make sure that am not wastin my money ... !!!
now i drive the car in 1.2 bar all the time ,, with the meth system i ran 1.4 ,, the car was really great .. have some issues leakin boost ... but its fine ...
thanks
yousef
Old 03-17-2010, 10:19 AM
keithta's Avatar
I would at 1.6 bar just to be safe. You will need to get the car re-flashed with a new tune file adjusted for the larger injectors as well. Check with Protomotive on that. Good Luck.
Keith
thanks bro ...
thanks
yousef
Old 03-17-2010, 10:23 AM
ysfg35's Avatar
Keith
yes sure i will do .. thanks bro .. you are really kind person
Old 03-17-2010, 10:24 AM
Betim@BBIAutosport's Avatar
Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !
Hi,
I would run 60lb injectors with an extra pump in line. You will be good up to and around high 700 to low 800 WHP.
Kindest
Old 03-18-2010, 11:35 AM
ysfg35's Avatar
Originally Posted by Betim@BBIAutosport
Hi,
Kindest
thnx alot man for your answer .. but i think goin to 80 lb injecters is safe with new tune
thanks alot
Old 03-18-2010, 11:39 AM
keithta's Avatar
I believe the 997tt factory injectors are 60 lb stock. The factory twin pumps in the tank are good for over 800 whp easy (already tested).
Keith
Hi,
Kindest
Old 03-19-2010, 01:50 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Are you running straight methanol or 50/50 mixed with water?
Quick Reply: GT3076 .63 ars
