Trouble with TPMS
Trouble with TPMS
Well I finally picked up my 2007 Turbo yesterday, and part of the CPO process, they put on new rear tires. Driving home I got a message stating that the tire pressure monitoring system was inactive and I need to set new parameters. I have been fooling around with it for about an hour and still no luck. I have put in summer tyres, clicked everything in allegedly right per the manual, and still get the red exclamation point and yellow tpms warning. Any suggestions?
-Getz
-Getz
Once you reset the TPMS, you do need to drive for several miles. IIRC, the fronts come online before the rears. If you have already done this, then the idea they forgot the sensors is probably valid.
I've had a faulty sensor and still had the 3 other tires show up so my question is do you see pressure listed for the front tires?
If not, it may be that the sensors were used on other wheels and not put on the ones on the car.
If the car was CPO'ed the dealer didn't do a very good job if they missed out on the TPM sensors.
There really is no way to "forget to install the sensors" The sensors are the valve stem. If you have aluminum valve stems on all the wheels you have the sensors. Im sure they just forgot to set the parameters (which you already did). After you set them up like you said you have to drive the vehicle may take yo to 20+ miles. It has different guidlines it looks at, and they must be met before they are able to read. Just take it for a highway cruise and the light will shut off
Well the sensors are working as it displays pressure in all 4 tires, however, it keeps asking me to enter new paramters. I have no idea what that entails, as I have gone through the menu selecting the summer tyre option, ect., but still get the same error. It records pressures in all 4 as within the specs in the owners manual, although at 39 psi in the rears, that is higher than what I have seen in performance cars in the past. They had to order the tires in which took a couple of days, but the CPO process went well and the car is in great shape per the tech whom worked on it. I pushed them to get the car to me before the weekend as the tires came in late friday, so they must have forgoten to reset the system, which I have failed miserably at my attempts as well. I have definetly driven it longer than 20 minutes
-Getz
-Getz
You might the the following.
Inflate your tires to the desired levels.
Use the stalk on the left to:
TPM > Load > Partial
TPM > Set > Winter (probably not necessary, but easy)
TMP > Set > Summer
Go on a continuous drive until all four pressures are displayed. If this does not resolve your issue, go to the dealer.
TMP > Set > Summer
TMP > Set > Summer
Go on a continuous drive until all four pressures are displayed. If this does not resolve your issue, go to the dealer.TPM > Set > Winter (probably not necessary, but easy)
TMP > Set > Summer
-Getz
C5tt
10-24-2015 07:35 PM
miken168
10-06-2015 09:21 AM
10-02-2015 02:23 PM
