Tiptronic in Sport mode
I apolgize for all the noob questions, and I promise I have been using the search section. However, I have noticed that when in sport mode that the tiptronic still starts from a stanstill in 2nd gear, where as the manual states in should start in 1st. Is this simply a misprint in the manual, or is it operator error :P I have been using the buttons to select 1st manually, but it seems somewhat counter productive to the whole "sport" tuning of the tiptronic. Any thoughts?
Thanks,
-Getz
Thanks,
-Getz
Thanks,
-Getz
Thanks,
-Getz
And at least for me when I turn on the sport mode you need to do it at full stop and it will go to first at next stop. not at where you at when turning the sport on. You can do it while driving too.
I think...
Thanks,
-Getz
Thanks,
-Getz
I think it works such way that you turn on the sport mode, spress brakes hard and start revving up. It switches to the first and launch control will beep. Then just release the the brake and you're off.
I think...
I think...
On sport mode the car starts on 1st gear but if you drive it normal it will strart to act like on normal mode
well at least there is in the 2010 model. You engage sport mode, step on the brakes, press gas and as the rpm's are over like 3000 it will beep to signal you are ready to launch. Have seen it myself.
There's a big difference between Tiptronic and PDK. Launch control is only available on PDK and the '10 model is PDK. OP has Tiptronic.
So tip cars do not have launch control...However by pressing the brakes and throttle simultanesly the car boosts up and when you release brake take off takes place...How do we name this procedure...?
Scary?!
Mine starts in 2nd gear when cold- once you run it up high in the rpm range and then come to a standstill it drops into 1st. You can always manually place it in first if you like too by using the paddles but if you shift back to Auto while at a stop it will revert back to 2nd.
We used to call it power braking.
Universally it is called power braking, but then again it refers more to the procedure where you want to light your tires up in RWD cars
