Softronic Software Criticism
#61
I would note here that it would be important to know exactly what the Porsche Warranty states in regard to software alteration, or whether it is silent to the issue. Legally, that is where the game would be played.
#62
Wake up guys. No tunner can assure that their flash is undetectable to Porsche neither that it keep factory warranty, besides Porsche power kits, but we never had that luck for the 997TT. The only thing that the tunners can assure is that the M97.70 engine is bulletproof in stock form, and that they have knowledge enough to flash the ecu and still keep a resonable reliability level.
PS: The key is to find a nice dealer to deal with. I rather flash it under Porsche warranty than wait to its end. This way you will still have a chance to get someone to pay the failure.
#63
Again... If you load back the True Original file Softronic sends you back to your car, there is no detection that you flashed your car, period, done, finally, etc... If you take your car to the dealer with the flash loaded to the car, they can connect with the PIWIS and see there is an update done to the ECU.
#64
While there maybe some truth to this, I believe it is way overblown. From conversations I have had with my tuner, he says the new knock sensing algorithms in the 997tts are truly excellent. Yes it was a problem for the old 993na and TTs which used to wait for audible knock before backing off timing but the new stuff is sensing it way before it is even audible. With CA 91 pump, we are working off knock sensors all the time.
#65
That is simply not true. Yes today's KS are far more sensitive then those used 10+ years ago, and the strategy they employ is far superior at detecting knock earlier and reacting quicker. But it is still occuring and must occure for the software to adjust accordingly. And that's the problem. Whether it's auditable to the human ear or not is irrelevant. It's still causing massive pressure spikes in your motor and hammering your bearings and rings. Running 91 in ca all the time does not mean you are seeing regular knock. Why would it?
The other question that's even more important for me is this : do you happen to know if the other well known US tuners (namely GIAC, EVOMS, Swizer, Protomotive) use a different approach from Softtronic? If they all use a different approach, then IMO that would raise a question. TIA.
#66
#67
How about FVD? Do they use a different approach from Softtronic ? Both of them use OBDII flash right now.
#68
Freeman - Softronic was the first to release the OBDII flash for the 997TT. FVD writes their own code, but uses the same flash interface. I am not sure of their tuning principles and equipment they use. I am not sure if they keep any of the above similar that Softronic does. They are a great company though.
#69
A 997tt in California is running around on the knock sensors all the time. Not just waiting for any random knock, but since they’re designed for 93-94 octane, and we have 91 octane/E10/oxygenated junk, the cars are forever optimizing their mapping for the fuel. Get a datalog of a California car, vs. an East coast car running 93 or 94 on stock programming and you’ll know what I’m referring to.
Following this argument, I wonder if it's safer for California/Arizona owners to use only either of these 2 tunes? There was a discussion on this a while back, at the time I believe about RS/Cargraphic Tuning. The program is of course developed for higher octane European gasoline, and I remember vaguely that it was an "unresolved" issue wether it should be used in California even if it had been available.
#70
Softronic has a 91 or a 93 octane map for users. We ALWAYS ask what pump gas the customer has to get them the correct file.
Cannaga - you did not read his post right. The 997TT is made for 93oct from Porsche. Hey it even says on the door to use 93 LOL. So the **** 91 that the west coast gets the car is always running on knock sensors is what he is saying.
#71
Re. Dave's post, I understood. On the West coast, a tuned car runs better, or at least has more appropriate timing map, than stock car!
Still trying to understand what Dave W & TTdude are posting regarding how the Softronic tuning is different though. Very interesting discussion.
#72
At the end of the day, the OP got Softronic and is very happy
#73
#74
#75
Dan, thanks re. Softronic info; I stand corrected.
As far as your 91 tune being safer than stock, I'm not so sure I would agree. You are getting more power out of your GIAC tune so it is tuned more aggressively than stock. The knock sensors are even more critical here.
