race fuel Questions
if you are tuned for meth allready , to use to raise octanes in fuels, its pretty much liek running on race gas.. you can add c 16 if you want to raise the boost additionaly for extra saftey measure . now if you still have your o2's leaded gas will eventually foul them.
but again, if you can not raise the boost level via different mad or boost controller then its a waste of time and money.
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
![Big Grin](https://www.6speedonline.com/forums/images/smilies/biggrin.gif)
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
(depending on your tune), no leave the meth on and run the c16 with it
Softronic tune with a base of 93 octane map works fine using up to 109oct as you have seen from our car. If you do switch to C16 it is a much different tuning. The water/meth is really only meant to be run with pump gas to act like race gas when running higher boost. C16 will also ruin your O2 sensors.
