Data logging?
Thunderolls - The durametric can measure values through the OBDII port that are important to your car. Mainly engine parameters. The VBox is a GPS meter that measures in essence movement.
BBYWU - Yep exactly! John you will first select what you want to log. Know that the MORE you log, the slower the response. So only check the important ones you want to see. Click start logging and do it to it!
mine is version 6.0.1.9
how do I start logging? under Tools, Logging, Enable Logging?
where do I choose the variables? want to choose boost pressure / rpm / lambda. Do I
set these under ENGINE MODULE / INPUT SIGNALS?
Josh/AWE
04-02-2020 05:38 PM
10-02-2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
