Tiptronic upgrade the movie :)
Its not that miple a guess, the kit includes electric transmition oil pump with thermostatic control system, oil cooler and oil cables, thermostat switch,wiring loom, and alloy bushings
As you showed a pic of the torque converter, did you ever thought change it for a race spec?
In the end, from the most elaborated to the basic kit, all will do the same job. A year ago i was almost to make a custom kit for the SMGII of my M3. The cooler, oil pump and thermostat would be from Mocal and the lines made by the installer.
Guys,
I have a 996tt tiptronic. I sent the gearbox to MKB for the upgrade including the TCU upgrade for tq limit to 1300nm.
I have an upgraded Torque Converter.
I do not have the upgraded TCU other than what MKB done.
Running full proto kit with k24/20gs.
Ran at 1.4bar today hard for 100 miles.
Gearbox is perfect, and we check twice the ATF temperature by pulling over. It was perfect. Remember the MB box already has an oil cooler.
I do have an aftermarket one, but have not fitted it. At the moment I do not see the point.
I know the MKB is not cheap and it is in germany, but it works. My previous gearbox would not hold 1bar without slipping and then that overheated the gearbox oil which compounded the problem.
I spoke with Max in Bahrain who had the same upgrade done to his tip. He had been running 1.4bar as well without any issues, but had the same problems as me before the upgrade.
The gear change is quick and it is not hard. It is like driving an Audi DSG.
I will update in a few more weeks once I put on more miles. Currently at 250 miles of hard constant testing with no Tiptronic DME fault codes.
I have no affliation with MKB. Just passing on that it worked and that is the important point.
Guys,
I'm very interested on the cooler, who makes it?
changing the TC will not solve anything, i believe it will make the car more violent and imidiate which for me will be less reliable as a dd drive
The original one we had was too large, but the above is fine.
Cost is around 200 EUR or less.
http://www.thinkauto.com/plist010106gweb.pdf (15mb)
It is a Mocal oil to air cooler, 194mm/25 row x 115mm , heavy duty, with 1/2" hose connectors.
996ttalot,
i checked their web side thx for posting, i've been looking for a tiptronic oil cooler long time now.
I know tiptronics have a water/oil cooler, this one is a oil to air cooler which might affect the oil pressure, i have my tiptronic removed so it would be a great opportunity for me to install it now.
I guess you have to connect it on the tip somehow and add extra oil to fill the extra tubes and cooler, pressure might not be affected, it will only make the oil go aroun.
Another thing is that it might drop oil temp below normal levels at normal driving, especially on winter.
Have you tried it ?
Do you have any pics?
996ttalot,
Have you tried it ?
Have you tried it ?
So my indy done some research and found the above. You can fit it with the transmission in - that is the good news. It is on order now and we wait delivery.
I will ask the questions you posed and come back to you.
What I can say is that the ATF fluid temp after 30 minutes hard driving at 1.4 bar on k24/20s was within range. But I did no brake boosting and to be fair i don't plan to after spending 5k EUR on the upgrade and install.
Ken
This is from the "Think Automotive" catalog:
Fitting an automatic transmission cooler.
Most mod ern au to matic trans mis sions tap into the re turn from
torque con verter to sump, where very lit tle pres sure ex ists, to ob tain
a full flow of oil through an oil cooler tube in the wa ter ra di a tor, a sec -
ond ary cooler may be con nected in se ries by in ter rupt ing this flow
cut ting one of the oil pipes lead ing to the wa ter ra di a tor and se cur -
ing hoses to the sev ered ends us ing hose mend ers . Where wa ter
over heat ing is a prob lem in ar du ous con di tions or where the pri mary
cooler has failed the wa ter ra di a tor may be by passed by con nect ing
di rectly to the Mocal cooler by cut ting both hoses, the hoses to the
pri mary cooler may be taped up to avoid the in gress of dirt if the sys -
tem is to be re in stated. Old Borg Warner gear boxes are pro vided
with means of tap ping the oil flow ei ther by a loop pipe or two plugs
on the right hand side of the gear box just above the sump. Renault
gear boxes have two plugs ad ja cent to the left hand drive shaft. Only
ZF boxes with an ex ist ing cooler can have ad di tional cool ing.
Cooling gearboxes and steering pumps
