60-130mph or 100-200km/h cold vs hot weather
I did some 100-200 runs these days and i noticed that my car is not as fast as before. My previous runs using PBOX were back on March where the weather was 22-25 deg C. Now is around 30-35 deg C and me car is almost half second slower than before, also humidity is very high 70-80%
I believe cars from UAE would be the most affected, please share your experience on cold vs hot weather.
thx
thx
it makes sense to me that you would see an increase in the times as the higher ambient temps mean the inter coolers are not as efficient so the charge going to the cyliders isnt as cool....and as we all know the cooler the better so you might be down on some power. not a direct comparison but my s4 for sure has more jump when the temps are in the 15-20C area rather than the 30-35c area ive been seeing lately
In my climate car can be 10-12% higher or lower power based on weather.
Play around with this calculator. I believe its for NA cars though but it will give you an idea.
http://www.csgnetwork.com/relhumhpcalc.html
thx
thx
what were the times you had in cold/hot weather?Also have in mind that every 3 deg of celcious rising,you loose 1% of power...So there is a great difference between cold and hot days...
10-02-2015 02:23 PM
