What exactly makes a BRV ?
trying to research answers to this question...where does a BRV fall under
Blow off/ atmospheric
Diverter/ recycled
What is a BRV?????...
the 2007/2008/2009 have VTG/BRV chargers?
This changed for the 997.2 TT?
What changed exactly and more importantly WHY?
Diverter/ recycled
thats right its the blow off valve
its the same u can use the 07 BOVs on the 997.2
and it helps the air flow to stay in the turbos for longer and more !
as an example from my experience and what i sow
i have a manual 997tt when i shift from a gear to another my boost bar get to the zero but when i fixed the BOV's when i shift with the same speed of shifting it doesnt get empty to the zero there will still be air flow in the turbines ..
hope this will help
hope this will help
BRV = Boost Recirculation Valve. The factory has a spring and rubber diaphram where aftermarket ones such as Forge, EVOMS, Agency Power use a CNC machined part with a piston and spring. This helps the boost come on faster and hold more consistant where the rubber diaphram part can bleed boost at the top RPM. These are mounted on your turbo. They do not vent to atmosphere like a Blow Off Valve. They are mounted to your turbo unlike the earlier 996TT.
Here is a picture of our Agency Power BRV's
Thanks for the response. Ok so a BRV is different solely because it is DIRECTLY ATTACHED to the Turbo unlike a diverter valve which has hose plumbing for the intake charge and the recycle return.
But the mechanics are same. Correct?
I have a quick question for you BRV experts. My car is 100% stock manual car at the moment.
When I first got the car and during WOT shifts from 1st to 2nd, for example, I would hear swooshing/blow off valve noise which sounded pretty darn cool. Lately, I can't seem to hear any noises.
So first question is do you guys hear noises during WOT shifts? I wonder if there is something wrong with my BOV. There is no loose hose etc and I seem to be holding decent boost.
Thanks so much svt. I took it to dealer just to scan and there were no codes. It's just odd that I used to hear slight pfffft noise before and not any more.
COBB Tuning
03-29-2016 09:26 PM
MrNurse
09-10-2015 09:44 AM
COBB Tuning
09-09-2015 09:13 PM
