Will VP MS109 make the car run lean if not tuned for it?
#76
I think your tune is working the way it was designed. It's pulling back timing when you switch from added ms109 to pump. If you compare your 3rd gear pull from 4200 with ms109 you're running a solid 12 deg. With pump in the same region, you're down to 4-6. So your tune is working as it should. Others may have a different opinion.
#77
I think the car now knows there's almost no ms109 in the tank as you can see timing is really pulled back in the mid range compare to the logs i made a couple days ago. However afr didnt change much I guess it's in the tune.
#78
It's disappointing that you haven't heard back yet. I'm not surprised considering the issue at hand and that you're dealing with a European company. I think you should find a communicative US tuner and upgrade to 700 with a good set of ICs. There are several great options out there. It will come down to who you feel most comfortable dealing with.
#79
I would be happy to discuss it with you. Feel free to PM me anytime. I think you've done enough datalogging. The data is pretty consistent. It appears to me that you're tuned on the lean side which is causing your ECU to pull timing. You need to get your lambdas in the 0.80 zone. If you really want to safely max out your power you need a tune specific for ms109. You can run ms109 with your current tune which will provide a measure of safety at WOT pulls but you won't get max benefit because your timing will be limited by the tables and afrs set in your current tune.
#80
Yes, i think i have logged enough. Not much change from AFR regardless of fuel, but timing really backed off with pump gas.
I will probably look at proto tune if FVD can't help me out. It's great that you can get both pump map as well as 100 octane map from proto.
#81
best of luck
markski
2001 996TT 3.6L and stock ECU
#83
Smart man. It will give you a much needed sense of relief. Good luck!
#84
out of sheer curiosity, would there be any performance gain with stock ECU using race fuel? My guess would be know, that it starts at a timing of '93' octane, lets say, and would only downgrade based on knock sensor, etc.. and not advance the timing until it HIT the knock.. So I assume you'll see no gain, but figured I'd at least ask the question.
#85
We have seen stock ecus hit knock... the 997s are knock sensitive.
#87
proto all the way , my suggestion is get the proto tune from markski , that way you have todd AND mark for support , cant get any better then that ..
