997 turbo 1/4 mile time
im taking my 07 997 turbo to the track to see what it will run in the 1/4 mile...It has alot done to it..Its a tip, has upgraded champion motorsports vtg tubos, awe intercoolers, werks 1 cf intake, giac ecu tune, tubi exhaust and tubi headers..for suspension i have a gmg roll bar, sway bars, and springs..What do u guys think it should run when i convert my giac flash loader to race mode on race gas..will run ps2 cup tires..
You possibly could run a 10 but alot depends on conditions when you run and its pretty hot most places now...
I have similar modds and i did 10,8 on PBOX. My car is a convertible so you should be able to do better. I did that on 100oct pump fuel
thanks guys..anyone recommend a good throttle body and y pipe set up with the car being a tiptronic??has anyone tried the cayenne larger throttle body with the bigger plenum??
yes..a bit pricey though....i think i might go w the vivid motorsports cayenne throttle body setup..will gain hp all the way through the band, without going too big w the tiptronic setup..
