Proper way to launch a 997TT TIP
Tippies do not have a launch control function. Really only one way to do it on the autobox: turn off PSM, put in drive, stomp go-fast pedal, watch landscape blur in peripheral vision. Rinse and repeat
Your brakes...Basically your holding the brake while building the revs on the car and then releasing them...I've read where a few have ruined there brakes by doing this...
Try brake launch and you will be amazed...psm off,sport on,hold brake full with left foot and full throttle with right one...After 2-3 seconds boost display will show 0,8bar and then just leave the brakes...and enjoy the flight...
^^^ What did he say?????
I use brake/launch only when i have a GTR next to me on the traffic lights and i usually surprise them
what about little bit of brake and gas pedal half way and let it go really quick? I know it's not as fast as full brake full throttle but still faster than nothing. would that hurt the trani ?
I doubt you can damage your brakes if you holding the brakes from a standstill, there's no movement on the brake system. It's like using a linelock system on a RWD, that doesn't damage the front brakes. You sure you're not thinking about brake boosting from a roll race, where they hold the brakes while the car is rolling?
This is what i usually do, but again its not a good idea to do it repeatedly. Even if you do normal full throttle accelerations from a standstill without using the brake, one after the other is not a good idea. Always talking about modded cars producing around 600WHP
stuntman
Wheels/Tires
09-17-2015 10:04 AM
