CARRERA GT vs C6ZO6 vs My TURBO
Old 08-09-2010 | 08:43 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Originally Posted by besiktas
Something not right. First I suggest you to use two nozzles on the Y-pipe instead of one. Then get some logs with durametric and send them to Todd. I'm sure he will figure out what's wrong. And also check your meth setup, if everything is correct.
I have already done that
  #32
Old 08-09-2010 | 10:51 AM
unvmy996's Avatar
Originally Posted by milou
I have a single nozzle on the Y-pipe that sprays after a certain boost level, yes i had it fine tuned with the methanol but again not big difference in power, if any
kati pezetai... thats not right .did you hve i tuned with the meth to run , to lower temps . or did you have it set up and tuned to run for high boost , etc?
cuase , if you have it tuned to run for high boost , like a octane booster , you are the first and only person i know that meth is not making a diff .
  #33
Old 08-09-2010 | 11:06 AM
HiProfile Robs's Avatar
HiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond reputeHiProfile Robs has a reputation beyond repute
Impressive, good run!!
  #34
Old 08-09-2010 | 04:20 PM
vividracing's Avatar
Yousef your car is hauling a$$!
  #35
Old 08-09-2010 | 04:54 PM
milou's Avatar
[quote=unvmy996;2936821]kati pezetai... thats not right .did you hve i tuned with the meth to run , to lower temps . or did you have it set up and tuned to run for high boost , etc?
cuase , if you have it tuned to run for high boost , like a octane booster , you are the first and only person i know that meth is not making a diff .[/quot
den xero ti paei strava, i did a few datalog runs using the methanol and had them send to Todd who was amazed from the resaults, but on road runs using PBOX i cannot see any power gains.
Today i tried sunoko 109oct and i did 10,8sec 1/4 mile soft launch with 35deg celcius.
I can see great resaults with racefuel but not with Methanol
  #36
Old 08-09-2010 | 05:19 PM
  #37
Old 08-09-2010 | 05:48 PM
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
are you running 100% meth? Are you sure about the purity of it? Maybe your source for methanol is not good. Sometimes that happens. Try some other source for meth.
  #38
Old 08-09-2010 | 11:15 PM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
[quote=milou;2937360]
From what i understand the Meth will not give you the gain as the racefuel, the result will be better than the regular fuel and less than the race fuel.
Another thing, i tested Sunoco fuel and VP109, my car did better with sunoco fuel.
  #39
Old 08-10-2010 | 12:35 AM
unvmy996's Avatar
Your wrong , meth injection dramaticly increases your octane levels . But your car has to be tuned for it . And at the sane time keeps things in the engine cool.
  #40
Old 08-10-2010 | 01:00 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Your wrong , meth injection dramaticly increases your octane levels . But your car has to be tuned for it.
+1 agree
  #41
Old 08-10-2010 | 07:25 AM
milou's Avatar
I'm using Sunoko 99,85% methanol. By the way i don't run on methanol, i just spray some in the Y-pipe from 0,6b too full boost
  #42
Old 08-10-2010 | 07:33 AM
besiktas's Avatar
I get that. You may also try to make it begin spraying from somewhere 0,3 - 0,4 bar of boost.
  #43
Old 08-10-2010 | 07:52 AM
milou's Avatar
i'll try that and see what happens, my guess same sh*t
  #44
Old 08-10-2010 | 11:17 PM
ysfg35's Avatar
good luck bro ..
  #45
Old 08-11-2010 | 07:43 AM
speed21's Avatar
Great race!!. You guys can sure get away with a lot over your way. The whole place seems to be one big free race track.
