Durametric data logging-- High RPM AFR
#48
Dammit,
finally got out and did some datalogging in regular and sport mode and it looks like something didn't record properly. Don't know if it's b/c my laptop sensed "movement" and paused the harddrive heads or if it is the program. Are you guys using the latest durametric version 6.0.3.1?
I'll post the part of the numbers that did show up and see what you think.
#49
yes, we all using the 6.0 version. It's the software that sometime pauses; you have to restart the software and relog it. When you finish logging, press "stop" then "export", then you can save it in a excel file.
#50
You can try the latest beta version durametric from here;
http://www.durametric.com/downloadV6.aspx
It's different from regular version 6.
#51
I am using the latest version. 6.0.3.1. My previous version was 6.0.2. I should have stuck with that and did a run before upgrading especially since I'd read somewhere else that someone was having a problem with the latest version. d'oh!
Guess I'll give it another go tomorrow and hopefully it won't pause.
#53
The little birdie told me a new update is coming soon.
Durametric, all versions, is still not working correctly with 2010/2011 DFI Turbo ECUs.
Hopefully they will have the issues resolved before too long.
#57
I ran into the same freezing issues back in January when I was using an earlier version, 6.0.1.x. I contacted Durametric and they asked if I could send them some communication logs. Eventually they worked out the bugs but there might still be a glitch with Windows 7. If you are still having problems, be prepared to submit the following information.
To generate and send a communications log to Durametric.<O</O
1. Open Durametric and click on Tools->Logging->Enable Logging. <O</O
2. Restart the program.<O</O
3. Attempt to capture data values as previously performed. Run the program with only 1 data value, then 2, then 3, then 4 values selected.<O</O
4. Upon completion of these actions, send the log by clicking on Tools->Logging-> Send log to Durametric. <O</O
5. Select the appropriate log (indicated by date/time stamp) and complete the remaining fields.<O</O
6. Click Send Data. This requires an internet connection, but you can send the log at any time after it’s created when an internet connection becomes available.<O</O
<O</O
Along with the submission, also send the exact computer specs (RAM, OS, Processor speed, Hard Disk speed). <O</O
#58
TTDude
Good catch on the dyno chart. Thanks for the good sense injection---I need one of those way too many times a day. OTOH, the quality of the original gives pause re: that shop's abilities. Not picking at nits, just saying...
#59
For pump tune, I saw about 9-10 deg timing and lambdas around .78.
<O</O
<O</O
#60
Markski kindly posted a screen shot of a stock 996tt timing/lamda maps. As you can see timing is not static but dynamic, depending on load/rpm but it can go into the 20s up top. My 9-10 degree was for high load (>200) 5-6 rpm. I haven't measured it on a flat surface up top but I suspect that value would increase (I don't know what my top end values are set for). Of course boost factors into the equation too. You'll know if your timing is being pulled as the value will not hold steady but decrease and lambda/boost will likely drop fairly quickly as well.
Stock 996tt timing maps
10-06-2015 04:43 PM
PelicanParts.com
08-26-2015 05:25 PM
PelicanParts.com
08-26-2015 05:24 PM
