Zr1 vs 997tt
PDK is the great equalizer. DCT/PDK etc are the wave of the future. Just so efficient. No manual will be able to handle it. If these two cars had comparable power the PDK Porsche would have walked away nastily. The ZR1's power overcame the PDK's efficiency to a near tie. But the last race the ZR1 did pull up top with the slight jump that helped it overcome the PDK's wicked wicked shifts. Great driver in the ZR1 as he didnt lose alot of ground on his shifts.
An RS GT2 with a PDK [if one came that way] would be lights out for any car save the Veyron.
Cheers
Nothing like not losing boost between shifts! My old Porsche would have like a 1 Mississippi between shifts! Without that, the car would have been absurd. Same goes for any of these other manual cars.
Maybe, maybe not. ZR1's low speed problem is two wheels trying to put 600+ to the ground. GT2 would have same problem. If you started a roll on at 80 MPH with either car, game over for the Turbo. Turbo has three things going for it that gives it the advantage at the start: broad power band (power under the curve), four wheel traction and PDK.
Cheers
Cheers
Since GM did not really ever "fix" the issue with the ZO6, and clearly could if it were only suspension tuning, I assume it is because the ZR1 weighs more and that affects the suspension and handling somehow.
I actually don't like the handling of either of these cars that much -- they understeer more than I like and they communicate a feeling that you have to manhandle them to get them to go fast in the twisties.
From 0-300 km/h (0-186 mph), the ZR1 is indeed the faster car way up top (32.6, fastest time I can find). However, with just a flash and a drop-in filter, the 997TT PDK is just as fast as a ZR1 to 186 mph (31.2 vs 41.9 for a stock PDK TT).
A stock GT2 RS, however, is faster than both (28.6).
A fre-lash and a drop in filter is no longer stock.
Just about everyone I know with a ZR1 runs a "12% kit" they get somewhere with a smaller pulley a re-flash -- most also have dummy O2 sensors installed but then I know a lot of folks with only a reflash that that that precaution, the reflash erases the factory torque limitation which in itself unleashes a good deal of added omph.
I don't which would win but my point is that once you start the "with just" game there is no stopping and there is always a faster car.
Factory cars come with stuff we just ignore in the aftermarket -- mainly a tune that will tolerate 100,000 miles of abuse and "drift" from factory specs and still stay within emissions limits. I respec the manufacturers for abiding by the rules and the stock cars are their best attempts to do that, so I judge the relative merits of cars by how they do quite literally, "out of the box."
Currently the ZR1 is the big dog among stock cars (at least all those below the list price of a new 458 Italia), particularly in situations like this, where the "heat soak" that always gets to a high RPM turbo sooner and more than it hurts a lazy pushrod V8 just killed the Porsche in the second race: I am certain a cool and fresh 911 turbo would have killed the ZR1 again.
You are correct. That's exactly why I caveated my statement with; "However, with just a flash and a drop-in filter". That would imply, not stock.
Stock (meaning without a flash and drop-in filter), with 138 less HP and 300 lbs more weight, a 997TT PDK is close enough in acceleration to a stock ZR1 that one mistake by the ZR1 owner and the P-car wins.
I'd get the 997.1 again b/c of the overall driving and ownership experience but wonder how much power is needed to keep pace with one from 20mph up to about 150mph? i.e. tune plus exhaust or does it need upgraded vtgs too?
