Fault P0021
Fault P0021
I just got this code for the second time today...I got it early this morning after I left the bank...I went home read the code and did a search on the forum regarding the code....I went ahead and deleted the code and went a for 40 mile cruise and it didn't come back...Well I just started the car and the code is back...I called the dealer but sevice is closed...My warranty expires in a couple of days and the CPO will kick in...Hope its just a bad cam sensor and not a bad cam like I read on one thread..Wish me luck...I also hope they can arrange a loaner on short term notice on Monday, since that is my day off....
Did it just go away? I wasn't pushing my car at all...After I deleted it the first time, I went out and pushed the car to see if it would come back on and it didn't...Then when I started it in the garage a few hours later it came up again...
This code came up on my car showed up as P2100 using durametric
2100
Throttle actuator control motor circuit/open
Implausible signal
and I cleared it.
Spoke to Todd/Protomotive and he informed me that Durametric shows up codes in reverse(P2100) and the code would have been P0021.
I have driven over 500 miles since the reset and it has't come back.
2100
Implausible signal
and I cleared it.
I let it sit for a day or so and when I started the car again it wasnt there. I had purchased a 50 dollar tester to see if the code was still there though and it showed up on the tool, so I am guessing even if it doesnt show up it might still be in the system.
2100
Implausible signal
and I cleared it.
2100
Implausible signal
and I cleared it.
Thanks for the info...Mine is still there and thats a good thing I guess...This way the dealer doesn't brush me off and send me on my way!
I just called the dealer that I bought the car from and the first question was have you modified the car? I said yes I have exhaust on it...He told me most likely that is my problem and exhaust voids your warranty...Needless to say I told him I can't bring it in and called another dealer....I've been to the other dealer before and all they did was complement me on the exhaust...I made an appointment with the other dealer...I guess some dealers have a zero tolerance on mods while others don't...
Yes, my dealer is the same way. They won't even put on aftermarket wheels. We all take our chances with warranty issues when modding. People can cite the Magnuson-Moss Warranty Act but in all practicality not something you want to deal with. Good luck with your repair.
