2009 Turbo 6speed transmission fluid question
Guys, what transmission fluid are you all running for you manual users out there? I believe our weight is a 75w-90 (with the NON-slip versions preferred i.e. no friction modifier necessary). My research shows it's the exact same fluid for the transmission and differential (may be the same fill hole and drain hole...I'm not sure). Please let me know if I'm wrong on any of the above. And what is the "all wheel drive controller oil?" Thanks in advance for your responses!
Transmission Fluid Interesting Find...
This thread wasn't too popular, but for what it's worth, just got my turbo back today with the new clutch (from Protomotive) and the new Shell transaxle fluid and it is TWICE as good as the stock setup! The shifts are MUCH more precise and smooth, and the clutch is just as friendly as the stock setup, but bites harder! The clutch slippage is completely gone...couldn't be happier! Hats off to Todd at Protomotive...he really knows his stuff!
Gbox transmissions (out of Colorado) told me the clutch fluid from the factory is VERY robust and doesn't need to be changed till 60,000 miles...I believe the owner's manual calls for 100,000 changes?? Gbox is extremely well respected on this and other forums. (See my earlier post for some very interesting data about the Audi fluid being the same fluid as the Porsche stuff...I received the Shell Porsche fluid and it is much darker than the Audi fluid...so, it's not the exact same, but probably meets the same spec...which is what Gbox probably meant anyways. The tranny shifts better with the Shell fluid than with the stock Mobil product).
2lflat4
11-18-2019 06:05 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 06:50 PM
08-20-2015 01:17 PM
ECS Tuning - BMW
08-19-2015 10:29 AM
