Tuning and the Real Facts
#121
I wanted to touch back on this question as I have received more info on this . Some reports by dealers has been that a Tuned file caused an insert to rotate in the head in which causes a cam fault. Im not aware of any tuned file by any tuner or even Porsche that would cause this. The vario cam is actuated via oil pressure from a solenoid. These solenoids are in fact what most of any issues are from and is either caused by a short in the windings or broken or contaminated spring plunger.
Any inserts in the water cooled head as in the 996 or 997 coming loose would be from inproper tolerances unless severly overheated. This has not been an uncommon problem over the years and Porsche has always corrected it. These parts are all manufactured for Porsche by other companies and have to be kept in check by them.
#122
Scott, here is a question that I always get asked about Softronic... How does the tuning take into account different environments such as altitude. A customer in Colorado would be different then one in Arizona. Or does that not matter?
#126
The 964 started to use a barometric pressure offset or compensation. The jump to the 7.8 DME in the 996TT and others not only improved on this but added more compensation or rather table adjustments for alt and density etc. Basically most tuning to a car in Florida at higher temps, humidity and at sea level when set correctly within these parameters would be OK also in Colorado. When I mention set correctly I would state that it would be adjusted with these variables in the Porsche (Bosch) file. Problems could arise if the tuner was only capable to make boost and timing changes as an example and exceed the correctable variables.
#127
No problem and Im glad you are enjoying your car .
#128
The stage 2 file has been dynoed at about 80BHP. The stage 3 is much faster than all others posted yet it could go into limp mode. I have held back in sending this file out for this reason. Yes it would be very fast and shows high gains yet why when it can go into limp mode? The file has broken all times that I have seen or tried yet I will not release it until it works properly. I do not think getting a very low trap speed and end it in limp mode is worth the press. I'm confident that it will be completed shortly though.
#129
What type of hardware modifications is targeted for stage 3 file ?
Thanks,
Emre
#130
The stock MAF is good up to about 640BHP.When the HP is increased beyond this point the file can go into a pre set configuration given the parameters set to that point. These settings are similar to how a Mafless car runs.
OK this is a question for all to think on and perhaps reply. You could say a riddle me this.
The 996TT uses the same MAP as the 997tt.1 and 997TT.2.
The 997TT.1 can run Mafless yet has a MAF as does the 996TT.
The 997.2 does not use a MAF Though.
What is the difference as to why these cars run this way?
#133
Here is a before and after dyno. Consider that a exhaust usually accounts for about 10-20whp. The stock exhaust with 400cell cats is a cork, so you will see more torque, but less topend. Still HUGE gains - http://www.vividracing.com/blog/proj...he-next-level/
